Question about Brother MFC-3360C All-In-One InkJet Printer
My brother mfc-3360c printer is not printing in black
  • ohsing Mar 16, 2009
    my 3360c is now on maintenance mode. im pressing arrow up but it's not responding. the lights are just blinking. help! what to do?
  • kmjstr Mar 27, 2009
    I have the same problem...... my black ink is not printing..... i have changed several times and nothing...... I follow the instructions and all i get is light flashing everywhere....... When I reach to maintenance... I cannot pass for there because i dont know which button is the set..... Can you please help me???????
  • 57 Answers
Hi there
check the black ink
thanks
Hamedo
Posted on Nov 26, 2008
I have a brother dcp 150c is not printing in block ink. can you pls help me with this prob. :) thamkz
Posted on Jul 23, 2011
  • 30 Answers
To enter maintenance mode. press menu, mono start, 4x s arrow up.
using arrow up look for number 8 then press set
using arrow up look for number 0 then press set
then press mono start repeatedly until the word purge appears on the screen
using arrow up look for number 7 then press set
using arrow up look for number 3 then press set
brot dapat mg-zero n un
then using arrow up look for number 9 then press set
thats all about how to reset purge
Posted on Feb 17, 2009
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Will not print error
Hi Ok try this it may work.
All the best good luck
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Posted on Sep 15, 2011
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Hi Guys I have a Brother MFC 3360C the problem is i have replace a new Black Ink Cartridge and the machine cant print black anymore it can only do color. What cause this to happen and also what is a...
hi...
as you repalced please check the following.
1.check weather the catridge is been placed correctly and in correct position
2.when you get a new catridge there is a protective cover placed in the outlel of the catridge so please check weather you remoced that protective coating.
3.the outlet may be blocked by the old ink which got dried up. so please clean the outlet of the catridge and try once
if may answer was usefull please vote
Jul 14, 2010 | Brother Multi-Function Center MFC-3360c...
Printed page do not match screen colors on a MFC-3360c brother all-in-one printer
Clean print head it may work properly. else
find out which color not working. replace the color ink cartridge
LC51BK Black color
LC51C Cyan
LC51M Megenta
LC51Y Yellow
Aug 25, 2009 | Office Equipment & Supplies
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
Aug 05, 2009 | Brother MFC-3360C All-In-One InkJet...
Brother mfc3360 blank ink doesn't print
brother is good printer,there are many facitil as we can block one type colour as black or colour . look once a time in your printer option.or setting. , Is there on type colour is set only?
Jun 20, 2009 | Brother MFC-3360C All-In-One InkJet...
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
Will not print.
What a ditz, it just needed a new ink cartridge.
Jan 23, 2009 | Brother MFC-3340CN All-In-One InkJet...
How do I remove paper tray on Brother MFC-3360C
you just pull the black tray you look doen infront of mfc-3360c
Jan 01, 2009 | Brother MFC-3360C All-In-One InkJet...
Brother MFC-3360C All-In-One InkJet Printer Logo
798 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
