Question about Video Game Consoles & Games
THE PS3 IS NOT PUTTING OUT A IMAGE ON THE SREEN EITHER IN HD OR AV. NO SOUND NO PICTURE, IT NOT THE CABLE OR THE TV PORTS. AO I THINK IT THE PLAY STATION 3 WHICH IS THE PROBLEM?
  • 903 Answers
Have you tried resetting the display? Press and hold the power button on the front of the console until you hear 2 beeps. If this does not help let me know and I will see what I can find out for you
Posted on Nov 26, 2008
How do I get PS3 to work on Panasonic TH-50PX70A HD TV?
does the TV work as a stand alone TV with an antenna . if so just use the analog for it and the HD for watching TV
Jul 26, 2015 | Sony Video Game Consoles & Games
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
I have a ps3 i play my ps3 on my normal television then i put it on an lcd flat screen tv i conected a hdmi cable to my ps3 because i conected put it on an lcd tv. then i put it back on my normal tv but...
ok to reset the video and audio port back to the av port for a normal tv when the ps3 is off hould down the on button unit it beeps 2x fast then it will got back to original setting
if u put in hdmi it will take over the av port so u have to chanage it back to it via ps3 settings or the reset option
hope that helped
Jun 14, 2009 | Sony PlayStation® 3 (80GB) Console
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Picture won't show up.
well make sure that the av cable is in tight in the back of the console and if it is wiggle to see if u can get a picture or somthin
Aug 03, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
