Question about Fujitsu Siemens AMILO Pro V2000 Notebook
TURN ON WIRELESS ON LAPTOP
CANT GET WIRELESS TURNED ON ON MY LAPTOP.MY WIRELESS ROUTER IS FINE AND I CAN ACCESS INTERBET BUT CANT GET MY WIRELESS TURNED ON ON MY LAPTOP.ITS A FUJITSU SIEMENS LI2735
    Genius:
  • 1,913 Answers
Check your wireless working fine
go to my network places.then view your wireless network if any network u see then connect.
also if your router is setup in security mode u have to add your wireless mac addresses in allow list in your router,
type in run "ipconfig /all" then u see mac adreses.
Posted on Nov 26, 2008
How to connect to the router, i can't see wireless light turned on, on the router
First check the power-cord from the router to the electric outlet it may be the power supply cord bad or the fuse on the router when bad
May 14, 2016 | Dell TrueMobile 1184 WX-6215D Wireless...
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
I cant connect to the internet on my laptop i do have the wireless but cant connect to the internet
Press Fn +F5 key then turn on wifi. Also make sure wireless switch is turned on.Then check if sitll not connected then uninstall wireless network driver from add remove programs in control panel then reinstall. Then if you are able to connect wifi then still not access internet then follow below to configure wifi router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN setting and set as your internet service provider settings.Click on wireless and enable it if it is disable then save settings and restart router. Then check. . Let me know if you need further assistance. Thanks for using FixYa.
Aug 11, 2010 | Westell Wirespeed ProLine 6100 Router...
On my gateway NV5378u laptop the wireless access is turned off. How do I turn it on? There is no switch, and no hot key, and I need to get on the internet. Thanks!
aha another gateway user. my laptop has a small slider switch that turns the wifi card on and off. look for yours. if you dont have an on n off
your is probably on.....you need to know if you have a wireless signal to connect to from the router. if you dont have wifi turned on ( on a router ) you cant connect wirelessly
Jul 31, 2010 | Computers & Internet
Actiontec (GT704WG) Router wireless access point problem
first of all try to turn the router of, wait for atleast 5 mins and then turn it on, if it still doesnt work,
click on start on the bottom left of ur screen
click on run
type cmd and click on ok
on the black screen type ipconfig
look for ethernet adapter local area connection
take down the default gateway written ther it is usually, 192.168.1.1
open internet explorer, type these no.s on the address bar
it will ask for a username and password, if you havnt changed it
it will be
username:- admin
password:- password
then click on wireless setup and c if wireless is turned on or off, turn it on if its off and then click on apply
if its on already, turn it off and turn it on again
check if this works. else we will have to reset the router but then u will loose all the settings on it done by your isp (if any)
Sep 26, 2009 | Actiontec (GT704WG) Router
I lost my pass phrase and cant hook up my new laptop without it ,my router is working fine on the other computers but I just moved and can't find my notebook with password or phrase in it.....how can I...
Are you saying you cannot access your router page like 192.168.0.1 or are you saying your forget your WEP key for wireless?
If you cannot Access your Router page Then a hard reset in order and there should be a black button somewhere on the back you can press and it should reset to system defaults, the password should be admin
If you dont remember your Wep key, go to your Router Page open it up And turn off the Internet security then Turn it back on while changing the password
Jun 04, 2009 | NetGear WGR614 Wireless Router
Cant see my wireless network on my laptop
You need to start by checking two things:
1. Is the wireless nic on the laptop turned on? Sometimes there is a switch or button on the laptop casing that turns the wireless nic on and off. Also you can sometimes turn the wireless nic on and off via a key combination on the keyboard. If you're sure it's turned on, take it to a wireless hot spot to verify that it is in fact picking up wireless networks in the area.
2. Did you connect to the wireless router using an ethernet cable, log into the routers configuration interface, and verify that the wireless access point is in fact turned on?
If the above does not lead you to a solution please answer the questions in this thread so that we can continue.
Jan 16, 2009 | Linksys Wireless-G WRT54G Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Laptop will not connect to blitz router
Make sure the laptops wireless card has not been turned off. Many laptops have a button where you can turn off the wireless card.
Jul 09, 2008 | Blitzz Technology (BWA611) Router
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
630 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
