Question about Cyberhome CH-DVD 300 DVD Player
DVD Player Problem
My DVD Player is bahaving very strangely sometimes. When I load a DVD, It says loading and would take about 5-10 mins to start. Somtimes nothing happens and sometimes it plays normally. ALso, when Eject button is clicked, sometimes it takes about 10 mins to open. Can anyone suggest me what could be the possible problem and a solution to this.
It happend to me to i cleaned the eye 4 times its a piece of junk waited 15 min for a dvd to eject
Posted on Jul 04, 2007
    President:
  • 3,130 Answers
Here is a website just for your Cyhttp://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewforum&f=28berhome model. If you do not see an answer for your problem, ask and you shall receive. Good Luck
Posted on Jan 06, 2007
SOURCE:
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
Mar 03, 2010 | TruTech DV288B3 DVD Player
Dvd player does not load when a disc is inserted
Check ur DVD for smushes,scratches and cracks?
Oct 19, 2009 | Televison & Video
Attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
Jul 03, 2009 | RCA DRC629N Portable DVD Player
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Portable DVD Player problem
The inter lock is sensitive add a little length to tab mine did the same
Aug 28, 2008 | Televison & Video
SyberHome 300 DVD player
Ok. sorry about the delay. Just started back to work. :)
If you are having trouble with your player, the first thing to do is what is called a hard reset. This is where you disconnect the player from the wall socket for 30 mins, then reconnect. If there were any lockup issues, this will clear them.
If the player still does bot work correctly, you can try to clean the laser lens. to do this you will need
  1. to take the lid off the player, load and unload a disc so you can see where it loads to. Sometimes, you also have to take off another internal cover that contains the tray and laser assembly.
  2. Eject the disc, and switch the unit off with the tray out. Makes it easier to get to the lens.
  3. Look for a small clear lens that is next to the platter that the disc sits onto when it loads.
  4. Using a cotton bud moistened with Windex(glass cleaner) gently clean the lens using circular motion. after cleaning, gently polish the lens with a dry cotton bud to be sure that there is no residue, or smearing.
  5. Turn the unit on again, the drawer will shut, open the tray and load another disc. If the unit was not working because of dirt on the laser lens, it will now work.
If the machine still has problems, there is not alot that can be done to repair a player of this value. They can be replaced for less than $40.
Good luck. I hope that you were able to fix the machine
regards
robotek
Jul 09, 2008 | Cyberhome CH-DVD 300 DVD Player
My DVD player is not working properly
It sounds like the player is defective, try to get a RMA ,or it or bring it back to where you got it from.
Apr 20, 2008 | Philips DVP3140
JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Mar 08, 2008 | Televison & Video
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
62 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
