Back to:
Tags:
Unitech PT630 Portable Terminal
Unitech pt630 scanner (by 2 users)
posted by mike4466 on Jan 06, 2007
I have all my inventory in the scanner and now it is stuck in kermit server mode..What do I do?Please help....
Thank you
Mike
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by PAUL505, posted on Sep 06, 2008
I have the same problem and I AM LOOKING FOR THE SOLUTION
Solution #1
posted on Jan 04, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I don't know if it is still usefull for you but could anyway help others...
When in "User-Ready" mode, Pressing "3" (COM) will bring you to the "Kermit Server Mode". From that mode, you can come back to the "User-Ready" mode by pressing "CMD" and then "ALPHA".
All of this is detailed in the PT630_Operation manual that you can find from Unitech Web site.
Hope that can help someday ...
Marc
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on unitech pt630 scanner:
I don't want to Accept this solution
Solution #2
posted on Dec 29, 2007
Not Rated (0)
mex-label
Rating: 0%, 0 votes
HELLO......... CAN HELP IN A PROBLEM WHICH I HAVE WITH TERMINAL PT630D WHEN ENTERING CODE TO CAPTURE REQUESTS THE AMOUNT, IN THIS CASE IT WILL RETURN TO CAPTURE BUT IT SHOWS THE Hh AND Fh OPTION THANKS IN ADVANCE
Thank You!
Solution #3
posted on May 21, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Do you still need the solution? You can warm reset and exit the kermit mode, and then the download ur data using PTComm.
Thank You!
Can you Help with these Barcode Scanners problems?
Barcode Scanners
i have a dymo turbo 300 thermal printer and i want to...
Barcode Scanners
hellow . how i can use the scanner of canon mp 140...
MY PT630 HAS A FULL STOCK TAKE DONE BUT I CANNOT SEND...
I open ptcom..... it wakes the scanner up but says the...
I have a portable PT630 and when we use it ounder Sun of...
Loading problems.
Repair Service
Find Barcode Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
