Question about Office Depot Ativa D5772 Phone
Handset nacannot find the base
ATT model 1445. Handset ran out of battery. upon recharging, it keeps saying "searching for base". Lookg at the base, I can find no ID to input. How do I make the cordless handset pind its base?
I plugged in the base. Hmm, was that important??
Posted on Nov 26, 2008
I have a panasonic kx tga652 phone it says base no power on several of my hand sets
That sounds like a handset model, from any of a range of DECT Plus systems?
Panasonic phone support is horrible, but they're pretty good about keeping manuals available on their Panasonic.com (may need to select USA) support site. Search the model number not of the handset, but the system found on the bottom of the main base unit.
There are enough versions and configurations that it's hard to guess specifics, but those series generally have the ability to power the base from a handset during power failures. There could be a need to reset something, or bad batteries or connectors in the handset in the base. Try swapping which handset is left in the base, and inspect the batteries in all handsets (sometimes removing them shows corrosion, or cleans a bad contact just from handling). Most of those use regular AAA NiMH batteries, and so they're pretty easy and cheap to replace if needed.
Jan 23, 2015 | Panasonic Lands Phones
Display keeps saying 'searching'
I don't have this model but I have had two Siemens phone systems. Typically, when the handset says "Searching" it is trying to connect to the base station (the part actually connected to the phone line). This can happen if the handset is too far from the base station to connect to it wirelessly. It can also happen if the handset has become unregistered from the base station (or was never registered to begin with). If the distance issue is not the problem, look in your documentation for how to register the handset and give that a try.
Sep 07, 2014 | Siemens Gigaset 4215 Cordless Phone
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
Hi My phone battery died and I recharged it. Now it is not recognizing the base and keeps searching.
Press and hold the end key, then while holding the end key, press and hold the # key. After 3 or 4 seconds the handset will beep and ask if you want to deregister the handset, select "Base unavailible" and confirm. Then the handset should read "Handset not registered". Place it on the base charging cradle and it should register.
Jul 08, 2009 | Uniden DECT 6.0 Cordless Telephone...
The phone keeps saying searching for base
To windyhorse 51 I pressed the button on thebase of the phone, and it works now,many thanks!!
May 23, 2009 | Vtech Digital Cordless Telephone VT-2568
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
D51A PD IS DISPLAYED ON MY ATT E2562 HANDSET. ANY
My E2562 handset 1 would not detect base and displayed D51A PD whenever I tried to manually register it. This fixed it:
1. Remove battery from handset.
2. Unplug base and unplug phone connection(s). Wait 30 seconds.
3. Plug in base.
4. Plug in phone connection(s) to base.
5. Put battery back in handset. Handset 1 should then auto register with base.
Mar 15, 2009 | AT&T 2230 Cordless Phone
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Jan 28, 2008 | Uniden Cordless Phone
Phone Installation - Out Of Service
Find the manual on the link below. Check batteries are charged preferably for a few hours then perform the reset as per the manual: To re-initialize the handset and base: 1 Disconnect the power to the base. 2 Remove the handset battery pack. 3 Wait at least 15 seconds. 4 Insert the handset battery pack. 5 Connect the power to the base. 6 Put the handset in the base to re-initialize. 7 Wait for handset to display READY (or handset name). http://telephones.att.com/docMgt/public/art/306/2255_.pdf
Jul 28, 2007 | AT&T 2.4 GHz 2255 Cordless Phone
Office Depot Ativa D5772 Phone Logo
295 people viewed this question
Top Office Depot Lands Phones Experts
k24674
Tom Chichester
Are you an Office Depot Lands Phone Expert? Answer questions, earn points and help others
