Question about Saeco Magic Espresso Espresso Machine
No pressure build up to make good coffee
After cleaning my saeco magic combi when I make coffee it pours straight out from the large screw hole on the brewer group rather than building up pressure so I can turn the handle. Obviously the coffee is not up to standard. Please tell me it wasn't just old coffee holding the machine together!
Turns out it was just old coffee holding the group brewer together. Ended up replacing the whole handle which cost AU$44, so not too bad really. It's like new now.
Posted on Nov 27, 2008
When I go to make a coffee on my Saeco Magic Comfort, it comes out in droplets from one side, there isn't a steady flow.
Have you tried cleaning the inner brewing system. Google the manufacturers website & model#. Look for cleaning unit info. I use half white vinegar mixed with water to clean the calcium from the water & the oils left by the coffee
Jan 15, 2015 | Saeco Magic Comfort 103467 Espresso...
Saeco magic
look like or brew unit is block if you didnt change the kind of cooffee or play with the grinder to fine of a grind normally the grinder should be at 5 or 6 the brew unit the top part with side pipe remove the 2 screw be carefull there a little spring and rubber seal and a little ball of glass remove notice how it goes so youll be able to put back after removing those part clean the hole all the way to the to the filter it should do the trick let me now how it turn out thanks pierre
Aug 01, 2009 | Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco pressurized portafilter gets stuck in the locked position
No, no... He has a Saeco pressurized portafilter which has a valve that will not allow coffee through when the portafilter handle is pushed all the way to the right. His handle is locking in the rightmost position; this is not a grounds problem.
mjtourig: Can you not just nudge the handle to the left before you pull a shot to unlock it? If it is too clogged for that, try taking your portafilter apart to clean it. You'll have to remove the 3 screws on the bottom, and be very careful the entire time that you do not lose any of the parts (in particular, there is a spring under one of the screws that will want to pop out, and a tiny white plastic thing under that spring...). Good luck!
Mar 29, 2009 | Saeco VIA Venezia
Saeco magic deluxe
use a little steel wire in the hole in the pipe to remove old milk residue you dont have to go to deep in the pipe 1 or 2 inch inside you have to remove the black plastic piece that goes in the milk thanks pierre
Jan 14, 2009 | Saeco Magic De Luxe Espresso Machine
Leak
if you clean your brew unit and coffee lines infrequently you're coffee may taste differently when you do get around to cleaning them.
If you are not happy with the taste, I would receommend the following steps
1. A Good Descale (See our article here for on Descaling your Coffee Machine for details) - This will remove excess mineral build up.
2. Try a Saeco Cleaning Tablet in your brew unit - this will remove excess organic build up (Coffee and Grease)
3. Use only filtered water
4. Rinse your brew unit every time you empty your coffee dreg drawer
That should bring your machine back to optimal coffee making condition. If you are still not happy, try some different coffee blends for a while - a change can be as good as a holiday
Paul from Coffee Shrine
Saeco Coffee Machine
Aug 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe - no water flow
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Aug 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Via veneto won't make coffee
I removed the top filter where the water comes out and cleaned it good with a pin for all the holes, then I did the same for the coffee filter. I found alot of the holes plugged which would avoid the from alowing the coffee to come out.
Now it works like new.
May 24, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Espresso Espresso Machine Logo
129 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
