Question about Car Audio & Video
Anti Theft Alarm on Denon DCT-850R
The theft alarm on my car stereo went off and I do not know how to reset it.
  • 324 Answers
Remove the bettery cable for 10 mins to reset every thing.
Posted on Nov 26, 2008
99 explorer alarm disables. Motor dies
Anti-theft system can keep vehicle from starting , Alarm is for vehicle content theft , open door without key alarm sounds (horns) ! PATS - passive anti theft system PATS enables and disables the engine from starting ,it will not cause the engine to die ! You have some other kind of problem ! If the vehicle engine doesn't turn over an red light on top of dash flashes fast ,then you have anti-theft system problem !
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
Aug 17, 2016 | Cars & Trucks
Where is the reset button located in a 2003 Honda Odyssey for the anti theft?
If the remote was programmed before loss of power, push and hold the unlock button until the alarm stops. If not try locking and unlocking the drivers side door with the the key. This has reset the alarm on my 2001 Odyssey.
You will also need the unlock code to reactivate your stereo after long term power loss. It is on a card with the manual given to the owner of new vehicles. A smart dealer will put it on a sticker in the glove box. Otherwise you have to remove the radio and give a Honda dealer the radio serial number to get the unlock code. Don't try it randomly; 10 incorrect tries locks the stereo.
Mar 07, 2015 | 2003 Honda Odyssey
My battery went dead and when i got a jump start the alarm started going off
It is the anti theft device that sends the alarm off and changing the battery sets of the circuit in the CPU . Use a code reader to reset the CPU
Dec 01, 2013 | 1999 Volkswagen Cabrio
Isuzu rodeo 2000, LS, anti-theft alarm needs to be reset
This has to do with the Auto's Computer system and should ONLY be done by a Factory Rep who knows what he/she are doing. not a home mechanic chore!!
Jul 16, 2010 | 2000 Isuzu Rodeo
1989 300e. The anti theft alarm went off while driving the car now the engine won't start. We shut the car off and locked and unlucked the doors several times. The alarm reset and we began driving again. A...
This is the problem due to your anti theft alarm system. You have not mentioned which brand of anti-theft alarm system you have? Anyhow, most of the systems have a reset switch inside the kit, open the kit and on the main board, u will find the reset button, press that and hold for 5 sec, the system will be reset. Otherwise, there are 2 or 3 fuses with the wiring of kit, remove those fuses and ur engine will wake up but the anti-theft system wont work then, hope this will solve the problem
Sep 19, 2009 | 1989 Mercedes-Benz 300-Class
Battery went flat alarm does not work ,how do i reset
unplug the battery for about 15 minutes and hook it back up again... that should reset the alarm. if there is an anti-theft code for your stereo ... make sure you know it and how to enter it.
Mar 28, 2009 | Vehicle Parts & Accessories
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Isuzu Trooper anti-theft alarm
i put a new stereo in my 1998 isuzu trooper now the anti theft wont let car start what do i do
Aug 27, 2008 | 2002 Isuzu Trooper
If it is a stock standard radio in your vehicle. Contact the car company with your VIN # and they can supply.
If after market, Contact supplier of stereo or the maker of the stereo with the serial number on the head unit
Feb 09, 2008 | Denon DCT-850R
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
