Question about NetGear MR814 Wireless Router
Constantly losing connection
I have no problem logging onto the internet using my MR814 router, and I have no problem logging on from both my desktop and my laptop, both wirelessly. The problem comes about 15 - 30 minutes after I'm online. My internet connect will just drop. I have to unplug the router, plug it back in, and it will work for another 15 - 30 minutes. Is there a way to prevent this from happening? I am connecting to Verizon DSL. When I had internet access through the cable company, I was told by their tech support that their system changes the IP address every 15 - 30 minutes and apparently my router would not renew the IP address. Is there a way to make it do this, or is that not the problem at all? Thank you!
  • Klair Stonesifer Jan 08, 2007
    Mine is set to Idle connection = 0. And I lose connection when I am active. I'll be in the middle of whatever and I'm just disconnected. Is that setting what you are telling me to do? And if that is the problem, would it disconnect even when I am active?
    President:
  • 2,961 Answers
A wireless router if set at enable DHCP will always asign an IP address to each pc, and keep it, it will not alter until the next time your connected, and even if the first pc that you connected with, first next time, it will get the same ip address allocation. The solution may be that your router is set to disconnect from the internet after a period of innactivity. Go into router settings and look for something similair to (Idle connection-Never).
Posted on Jan 07, 2007
  • andrew pester
    andrew pester Jan 08, 2007
    The setting is correct, so see if there is a firmware update for the router, or get your ISP to do a line check.
    I had a similair problem for at least 2 weeks only to find the problem was at the exchange. and not at my end.
    Next time it drops connection go into your routers settings and see if it loses the dns addresses of yor broadband provider.
MR814 does not get IP address from my ADSL modem
try power cycle modem to clear out the computers onfo then it should connect to the router
Aug 10, 2012 | NetGear MR814 Wireless Router
I have forgotten my security key for connecting to the internet with my netgear wireless router
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
hope this helps
Nov 11, 2010 | NetGear Wireless router EN Fast EN
Can't connect to internet- suddenly after working for years, my router won't connect to web. I can connect with a direct connection from modem to computer
Nov 07, 2010 | NetGear WGR614 Router
Using Windows XP. can't remember NETGEAR DG632
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Feb 13, 2010 | NetGear MR814 Wireless Router
I want to use my netgear mr814 wireless router to connect to the internet but i cannot remember the password
which password you don't remember the Router or the Internet account?
if it's the router- you can reset it by clicking on the reset (very hard to find) button.
if it is the Internet password- just call your ISP and have them reset your password.
Dec 28, 2009 | NetGear MR814 Wireless Router
I have not ues my netgear MR814 for a long time
to use a internet more than one device: pc,ps3,.... you must use a router to have internet without any problems,
the router, resolve this question fast, you dont have to special config. for internet/network acess. Use the technology work for you. dont burnout your head.
Nov 22, 2009 | Computers & Internet
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Oct 29, 2009 | Linksys WRT54G2 Wireless Router
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
Having difficulty logging on to internet.
Re Router;
Is it properly configured with your DSL modem? Are patch cables porperly wired EA568A or 568B? Is your power to the router good? make sure all connections are solid. Check the cables with lan tester if possible.
Nov 11, 2007 | NetGear MR814 Wireless Router
NetGear MR814 Wireless Router Logo
142 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
