Question about InFocus Proxima DP9300 Multimedia Projector
Hook a laptop to the dp9300 proxima
I Have been trying to hook up my proxima to my laptop, but for some reason I do not get a picture, I just get a blank screen. What do I do? Thank you.
    Problem Solver:
  • 6 Answers
Assuming that you are on the correct input on the projector it may be that you need to toggle the image to the HD15 pin output connector. Most laptops do not auto output an image you have to send the command which is function F7 on some computers both held down at the same time. Also the native resolution is 1024X768 if your resolution is set to high it will not sync up. This is set in the display properties of your computer.
Posted on May 01, 2009
How do i hook lap top up
Most Laptops have a VGA output port. You would just hook this to the VGA input of the TV for video (picture).
You would then need to hook an audio cable from the laptops headphone jack to the TV's VGA's Audio Input jack.
Newer laptops have a HDMI output so that is easier and can hook directly to the TV's HDMI input for both video and audio.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
Can't attach to faucet
it go up just fine but it go down and thin it stop and i have to push the botton again again
Feb 02, 2013 | ASK Proxima Proxima DP5900, DP9200, DP9210...
Which function key do I use to connect my computer to the projector please?
it hased to be set eather to pc mode or to rgb mode, when you hook you computer to your projector press the input/source button than it should automaticly find the computer.
Jun 02, 2011 | ASK Proxima Office Equipment & Supplies
Hi, My Acer 4720 refuses to connect to a proxima or any other presentation device, no error, Alt F5 just don't work, and it did before.
You will probably have to re-set it up all again, to make it work, it's probably lost the driver etc, and if "it" is taken off, the laptop, reverts to single monitor mode, you will need to hook it all up to the PC and go to Video card properties, right click, the desktop, choose Properties, and then setup the dual screen setup and enable Spanned/Cloned desktop and enable the output. After you have done this you should be able to use Alt F5.
Feb 17, 2010 | Acer Aspire 4720 Notebook
We need to know how to hook the projector up to the laptop to project a power point presentation
You will need a VGA cable that can connect the projector to the laptop. This is usually the same cable that connects a monitor to a desktop computer.
Once you have the two connected, you will have to tell the laptop to send the video signal down the cable. This is normally done by pressing the FN (function) key on the bottom row of the keyboard, and the F8 key on the top. It will normally cycle through the following modes: laptop only (default), external, laptop and external.
Hope this helps and good luck.
Jan 15, 2010 | InFocus Proxima UltraLight S520 Multimedia...
When I connect my Acer Aspire One Netbook to my Proxima Ultralight LX1 projector it gives the ''Windows'' page and then stops projecting. It says ''Searching''
Hook up computer to projector AFTER projector is turned on. Power on.
Right click on your desktop.
Click on Graphics Options.
Click on Output To.
Click on Intel (R) Dual Display Clone.
Click on Notebook + Monitor.
Oct 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do i hook up macbook pro laptop to in focus
only if you have mac to dvi adapter. it's only set up for windows.
Aug 04, 2009 | InFocus Proxima UltraLight X350 Multimedia...
Projector getting too hot
comman to a projector to get hot in front and top center part
but not at the rear side
this might be
fan not working
filter need to clean
bulb life getting lower
open the cover check safety paper
might be burn out
replace new one.any hard paper
Jul 10, 2008 | InFocus Proxima DP6155 Multimedia...
Proxima x350
Did you have an image before? if not, sounds like you did not switch your laptop to the lcd screen (fn f5) keys. Please advice
Jun 08, 2007 | Nview Z215 10.4" LCD Panel with Video(16.7...
InFocus Proxima DP9300 Multimedia Projector Logo
256 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
