Question about Whirlpool SB160PEE Gas Single Oven
Unable to clear error message on panel...oven not operating
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
Posted on Oct 01, 2010
I am self cleaning my wall oven. I have an error message with F 10 but the oven will not respond when I push stop.
Flip the electrical circuit switch for your oven after 5-10 minutes watch what it does when you do. After it reboots follow normal procedures should respond properly. If not push your stop button keep pushing on it for at least 15 30 seconds this should clear it. If not flip the power switch again then watch it as it reboots when you turn it back on it should respond. What has happened is you have knocked the program out of operation mode. You need to clear that is why you need to shut the off to oven then start again.
Nov 19, 2017 | Ovens
Self-clean-mode not working, I get the "door" error message
are you sure it is an auto lock door and not a manual locking type .
Oct 22, 2015 | GE Ovens
I have Whirlpool double oven, model number gbd307pdb7, that after the self clean on the top oven quit working. The original message on the key pas was locked, then it said hot and lastly it had the error...
this most likely happened from when you self cleaned the oven,the oven gets up to 1000 degrees and can damage the electronics on the oven.i will never use this feature for this reason,i use easy off,but the f2 e1 error says it's a bad key panel or the touch pad that you push to control the oven.do you see upper and lower off?if you want to cancel the upper oven you press upper off,you can try to unplug the oven for like 10 minutes and see if it resets it or kill the power,pull the oven out enough to remove the top panel,unplug the ribbon and plug it back in and see if it resets,that code means the board can't read the touch panel,if you press the upper off and it clears and then returns the touch pad is bad part WP8300440 go here go to control panel
https://www.searspartsdirect.com/model-number/GBD307PDB7/1198/0125300.html?searchType=modelSearch&q=gbd307pdb7&searchTerm=gbd307pdb7
Sep 28, 2017 | Whirlpool Ovens
Tried to Auto Clean. Got error message: Door -F-5. It started to warm up but would not lock. What to do? Manual not to be found in house. Oven is about 13-15 years old. First problem I have had.
The F5 error code means that the control board has detected a error within itself and the control board needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button but if the error code returns the control board would indeed need to be replaced.
FYI when ordering the control board it also may be called the clock or eoc
GENE
Sep 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Started the cleaning cycle, and cycle stopped with a beep. Power is still on. Error F5 E1. The door is now locked.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at this LINK
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
Oct 23, 2010 | KitchenAid KEBC107 Electric Single Oven
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Whirlpool Accubake oven super capacity series 465
Mar 16, 2008 | Whirlpool SB160PEE Gas Single Oven
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Whirlpool SB160PEE Gas Single Oven Logo
227 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
