Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
My oven tripps the circuit breaker when turned on
When my oven reaches 400 or more degrees trhe circuit breaker is tripped.
  • 700 Answers
When the inside of the ovens gets hot like that what happens is that the hating leements expands with the heat and when the do the short out on the side of the oven. I just noticed the date but this is still the problem.
Posted on Dec 25, 2008
Hi I have a 4year old Lamona 4601 double oven, the top oven/grill works fine but when I turn on fan oven it trips the power on the main house fuse board.
When the main breaker trips it indicates current is escaping from the circuit to ground.
If it is a micro-circuit breaker that trips it indicates the circuit is consuming too much current - a short circuit.
Either way the wiring or the oven elements have a fault and need attention.
Dec 20, 2017 | Ovens
Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
May 25, 2014 | Ovens
Bosch hbn7052gb oven trips circuit breaker
That is interesting because the major current draw of your oven will be during startup and warm up. I think I would replace the circuit breaker. As your oven warms, your breaker could be heating up and pops at about 150C.
Might not be the issue but a reasonably cheap place to start.
Good luck
Semper Fi,
Z
Feb 16, 2018 | Ovens
Whirlpool accubake RBS275PDB6 will not heat up to preset temp
I am assuming the lower element is not working well. Go ahead and replace it. But first , go turn your breaker off to the oven and then back on. Often times it can be tripped but not showing due to the other poles not being tripped. The lower element is the cheaper one also.
Feb 24, 2013 | Ovens
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
Oven heats up but wont get above 160 degrees
I assume you mean it trips the circuit breaker. If the circuit breaker is good, that means the heating coil is bad, and pulling too much electrical current. Sometimes circuit breakers fail, and trip at say 5 amps when rated at 15 amps. Have you electrician switch that breaker with another one and see if there is a difference. If not, it is a bad heating coil.
Oct 19, 2012 | Bosch HBN5046AUC Electric Single Oven
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
May 20, 2011 | Frigidaire Ovens
Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
Jun 09, 2009 | Neff B1691 Single circotherm super...
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
110 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
