Question about Toshiba 27A33 27" TV
I have a 2004 Toshiba color TV 27".
I cannot get the TV to operate through my cable box. I have the remote control for the TV itself, but when I connect it to the cable box and try the cable remote, it does not responds.
Simply look up the codes or contact your cable company for the toshiba tv codes to input into the cable remote. you may also be able to operate the cable box via the TV remote if the correct codes from the tv owners manual are entered.
Posted on Nov 26, 2008
Why does it turn on, then off?
"HDMI-CEC", short for HDMI Consumer Electronics Control, is an HDMI feature many TVs and peripherals have.
If the TV is connected to an HDMI or a programmed remote is being used on the cable box the TV may be getting a second command via the HDMI cable.(CEC) Suggest disconnecting the HDMI cable and manually turning on the TV and see if it will remain on with just a blue screen, Try changing the input to antenna-DVD etc and see if the TV remains on.
You may need to check the settings in the cable box or DVD to change the auto control(CEC) feature. Or if you prefer controlling the TV via the cable box remote then you would not use the TV remote for turning on and off.
This can get very confusing because the TV and the DVD or the TV and the cable box will interact between each other. The problem can be more confusing if the components are not exactly compatible with the CEC. Also many remotes have the additional feature of controlling other components in your AV setup. Many times the operation is alternate action. So each cycle of the remote the TV changes state from on to off. If the two components are out of sync than one is on and the other is off. In that case not using the master on off of the remote but using the individual component setting allows for the two to be sync again. (both off or both on)
Nov 15, 2015 | Sanyo Televison & Video
How do I setup my Comcast remote control to operate my ViewSonic VX2703MH 27 inch monitor?.
Unless the monitor itself had a remote control (most do not), there is no way to control the device with another remote.
Aug 02, 2014 | VIEWSONIC DISPLAYS VX2703MH-LED Viewsonic
HOW DO I GET THE REMOTE FOR THE CABLE BOX TO WORK I HAVE THE REMOTE FOR MY TV BUT I NEED THE REMOTE FOR THE CABLE BOX TO WORK MY TV
Go to your cable provider website and check for programming instructions, follow the instructions and input the code for your TV, usually found on the same website. Your provider should also be able to help of you call them.
Jun 24, 2014 | Toshiba 27A42 27" TV
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Toshiba 32HL83 color line full screen
Some settings have got changed. Look for any jammed buttons on the remote control. Try removing the battery from the remote and try from control of the TV. Try resetting to factory default.
Aug 02, 2012 | Toshiba 32HL83 32 in. LCD HDTV
How can i control my cable box through my toshiba remote control? I need the code and step by step procedure. Can send me please.
Tv remotes are only for control the tvs only sorry.Ur cable box have it own remote,used the cable remote read ur cable box owner manual or call ur cable company for help by putting in the Toshiba remote codes for the cable remote to used.
Apr 22, 2011 | Toshiba Ct-90302 Remote Control
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd cable.box do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
Hello, I purchased my Toshiba TV 27DF46 at a thrift store and it did not have a remote and I cannot figure out how to get my av ports to work. I have tried changing the channel manually and using my...
There are several different options to solve your problem. You should be able to program your cable box remote to replace many (but probably not all) of the functions of the Toshiba TV remote that you're missing. Read the user manual that came with your cable box remote to find out how to program it to control different types of components. It's not very difficult and that would be your least expensive option. Another suggestion is to buy a "universal replacement remote" that are sold in many electronics stores. Once you program those universal remotes, they will perform most/many of the functions of the original (Toshiba) manufacturer's remote. A "universal replacement remote" can cost anywhere from $20 to well over $100 depending on how many electronic components you want to control. My best suggestion would be to buy a replacement remote that was specifically made for your Toshiba model 27DF46 TV. There are many companies on the Internet which sell those remotes specifically made for your TV. The cost is usually between $25 - $35. One last inexpensive option would be if you already have any other Toshiba components (like a Toshiba DVD player), in many cases, the remotes are nearly identical and will provide most or all of the same functions. I would start by trying whichever option makes the most sense for your particular situation. Good luck.
Aug 11, 2010 | Toshiba 27DF46 27" TV
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
Toshiba 27A33 27" TV Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
