Question about Microsoft MS Xbox 360 Common Controller (DHC8G00004)
XBOX 360 Wireless Controller PC Connection Problem
I bought and have been using the XBOX 360 wireless controller for PC. Both it and another wireless controller worked fine for a while. However, recently neither of the two controllers will connect to the PC. Both will connect to the XBOX 360, though. When I put both the controller and the wireless USB reciever in detection mode, they act as if they have found each other, but then the controller immediately begins flashing again as if it isn't hooked up. I've even checked Windows game controllers and it is not visible. I even tried uninstalling and reinstalling the PC receiver, but I continued to have the same problems. On a side note, I had tried (and later took back) a USB headset. Since I haven't tried the controller since then, could this have messed something up in my computer's configuration somehow? Many thanks in advance!
WARNING: try at your own risk!
I kind of fixed it. The problem appears to be with the USB controller - specifically, my mouse (a Razer Copperhead) and the XBOX 360 wireless receiver. A lot of work went into the solution, but I essentially ended up uninstalling and unplugging all of my USB devices (you can uninstall them using device manager in System Properties>>Hardware within Control Panel. Look for Universal Serial Bus and uninstall everything in that category). Reboot. Then, I first plugged in the device in question (my 360 receiver). Afterwards, I one by one plugged in each item until I found the one conflicting with the receiver (my mouse). After that, I uninstalled all devices again and next uninstalled the drivers for the conflicting device (my mouse in this case) and rebooted again. After this, I tried several times to uninstall and reinstall the mouse and various USB devices until finally it worked (sort of).
I call this a partial solution because now I appear to have the opposite problem. My mouse seems to be conflicting with another device (probably the 360 receiver). My mouse refresh rate is very choppy. The good news (for me) is that I can uninstall the USB controller for the mouse, reboot, and both the 360 controller and the mouse will work fine... that is until shut down. Then I have to uninstall the mouse controller and reboot again. Needless to say, I keep my computer on more than usual now.
Posted on Dec 01, 2008
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My xbox 360 controller won't work on my Pc, my pc does recognize the controller but just recharge the battery why? ( O.S win7 )
The Xbox 360 controller only works on a PC if you have the Xbox Wireless Receiver for the PC or if you have a wired Xbox controller. If you are using the Play-and-Charge cable with a wireless controller, it will only charge the battery.
Feb 16, 2011 | Microsoft Xbox 360 Controller
"HOW TO" use xbox 360 controller on pc games
Most games support the gamepad by default. You should not need any software or setup. But you might need the Drivers for it... Check this out, hope it helps:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming&type=Gaming&sku=JR9-00001
Mar 31, 2010 | Microsoft Xbox 360 Controller
New Controller wont work with Headset
try to reset button on the both side (xbox and controller))
at same time it will work
for xbox reset buuton on the side censor
for joystick above the battery
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox-360 wireless controller doesn't sync at all
my xbox e87a2ee.jpg joystick this spot of cable is broke and i dont know what is sequece of colours in cable?
Oct 23, 2009 | Microsoft Xbox 360 Controller
Xbox 360 Controller Won't Connect To My 360....
You have to connect the controller like this: Somewhere on the XBox 360 controller there is a button that looks like this, o))) or something like that. Push that button and look at the XBox 360 round lights, they start to flash, that means you have to push the same button on the console. The o))) button should be infront of the console.
Regards,
Max
Jul 09, 2009 | Microsoft Video Game Consoles & Games
Just bought a wireless xbox 360 controller for the pc and i installed it but cant get it to work
the wireless 360 controller wont work because you have to get the adapter to use a CORDED controller for your computer.
Mar 12, 2009 | Microsoft Xbox 360 Controller
Unable to connect xbox 360 to Guitar HeroWT Wireless Drums/Guitar
pmac92,
Did you sync your guitar and drums first? They are just like a normal xbox 360 wireless controller, you need to sync them.
randy320sgi
Dec 31, 2008 | Activision Guitar Hero II for Xbox 360...
Xbox wireless controller
do you know the small button on top of controller. well press that and press the one on the 360 tht looks the same. its very small and its at the front of the 360 where the usb prts are. just next to tht. hold them both in till your xbox recognises it. i found this out as i wanted to play two player on my 360 and had to do the same thing
Dec 25, 2008 | Nyko XBOX CONTROLLER- AIRFLOW WIRELESS...
Microsoft Xbox 360 Wireless Controller for Windows
HI perform a system restore to before you installed the drivers
(start,Run System restore)
then reinstall them
should work :)
please rate .
Dec 17, 2008 | Microsoft Wireless Receiver For Xbox 360
Microsoft MS Xbox 360 Common Controller (DHC8G00004) Logo
4,546 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
