Question about Electrolux Epic 6500 Vacuum
Series 6500 motor shuts off, vacuum continues to run, not suction
I vacuum for about 15 minutes. The tempreture light come on and the motor stops. The the power nozzel still works, but not suction.
    Scholar:
  • 44 Answers
It's tripping the temperature overload in the motor. The most common cause for this is a clogged hose. Take the hose loose and attach it to the exhaust port under the back cover. You should be able to see if it's clogged and unclog it. I might also suggest taking it to your dealer. I don't think that machine's power nozzle should run if the overload is tripped. It sounds like the wiring may have been modified for some reason, but I can't swear to it. Good Luck!!
Posted on Jan 01, 2009
I have a dyson DC 3.5 model 11-6300 d1 it will run about 30 sec then shut down the green light will keep flashing whenever I tried to run it then shut down
the flashing light is to tell u that there is something blocking the suction of machine , most times its a full dust cup or hepa filter blocked this if allowed to continue will over heat the motor so it shuts off to prevent motor damage
Nov 30, 2016 | Dyson Vacuums
Stanley 3.5 wet/dry vacuum motor runs but suddenly suction stopped just like it does when tipped over, but didn't tip over
ck ball that saves the motor when container gets full of water , they sometimes get stuck inside the little cage there in an shut off suction
Jan 19, 2016 | Stanley 3.5-Gal. Wet/Dry Vacuum
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 Vacuum - Suction stops when hose is attached
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial.
You can ship the vacuum to http://evacuumstore.com/ and they can reapir it for you.
Mar 28, 2010 | Electrolux Epic 6500 Vacuum
Runs for a few minutes. Loses suction the shuts
It sounds like it's draging on the motor Also heating up the thermister switch. I would recomend having this look at from a vacuum repair shop ask for free estimates if you call around. save some $$$
Nov 10, 2009 | Royal RY9200 Bagged Upright Vacuum
Series 6500 SR won't start
Look for a restriction somewhere in the suction system. Inspect every last inch of it so you know it is clear.
Jan 24, 2009 | Electrolux Epic 6500 Vacuum
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
116 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
