Question about Apex Digital AT2008S 20" TV
No Picture I moved the TV to a new location and when I plugged it back in...no sound and no picture. We can watch a DVD using the tv and it is fine. The cable is plugged in and the tv is on cable! Worked great before I moved it....know we watch a blue screen.
  • Tina Rogers Jan 24, 2007
    Thanks for the help..even thou I didn't want a solution like that, The tv is 3 years old. Guess I should be greatfull I used it that long. Thanks again.
    Sergeant:
  • 308 Answers
As long as you can hook that same cable up to a different TV and get a good picture, you must have somehow damaged the tuner on the APEX - unless the set was mishandled while moving. Those cheaper brands won't take much punishment.
Posted on Jan 22, 2007
I have sound but no picture. How do I fix/
Click on the input button on your remote to make sure you have selected the correct location of your incoming signal. If you are just watching TV and have a digital cable adapter, unplug the power to the adapter and plug it back in. If you have pinched a cable running into the TV and are using a DVD player or other device hooked to the TV you may need to try another cable. If you are using red white and yellow wires for connecting a device try removing the yellow wire from both the device and the TV and substituting with another yellow wire from another device. Also make sure you try additional channels if it's just the TV signal. If you have cable you can also unplug power to the cable box to cycle it off and plug it back in.
May 01, 2015 | Vizio VBR120 Blu-ray Player with Internet...
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
I can't get any sound from it.. just great visual...what can I do?
Yellow plugs and jacks are the Video and that works. Red and White are the RCA sound wires from the DVD to TV.
OR
Your sound goes from the DVD to TV via a Fiber Optic or Fire Wire.
OR
You use Ch 3 on the TV and watch the DVD through a TV Tuner and use the TV Antenna Cable between the DVD and TV.
If that didn't help, let me know for more things to check like Audio settings on the TV.
AL
Apr 26, 2009 | Televison & Video
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Apex Digital AT2008S 20" TV Logo
110 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
