Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Not making espresso from beans
When I press the espresso button, it grinds the beans, packs them and starts brewing, however, espresso won't come out. It feels as if something is clogged because eventually it stops brewing and displays the "Ventilate" msg. I tried cleaning the brewing unit but this does not fix the problem.
Thank you in advance for your help.
  • 1,089 Answers
Are your coffee grinds wet? If they are you have a clogged brew head. Remove the filter screen. Then remove the 2 screws that hold the outlet manifold to the brew head. There are 3 things under the manifold. O-ring, tapered spring and a crystal ball. Don't lose any of these items. Now to clean the brew head turn the brew unit over to where you can see where the brew screen was. You will see 2 holes, 1 large and 1 small. Take a paper clip and straighten it. Turn the brew unit upside down and insert the paperclip into the small hole. Push the paper clip through and remove the plug. I have seen them over 1/2" long. Reassemble the brew unit crystal ball first, small end of the spring on top of the crystal ball, place the o-ring over the spring and place the manifold on top making sure the outlet pipe is to the outside of the brew unit. Put the 2 screws back and your ready to go. Run a detergent for espresso machines like Cafiza through the brew unit every once in a while to keep it clean. It doesn't take a lot of detergent and use the pre-grind setting and a large cup selection but don't put any coffee in.
Posted on May 24, 2009
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
Saeco Vienna - I turned on the coffee machine and instead of the usual whirling of the parts getting into place, it sounds like it is struggling to get into place. I looked inside and the bar is down where...
Hi Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Jun 13, 2011 | Saeco Vienna Espresso Machine
I put beans in where the grinds should go. help!?
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
The machine says FILL BEANS but beans are in it...yes, we did run out of beans but now it won't recognize beans. we cleaned it out, grinded , etc...but it still says fill beans. We also rinsed many times,...
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
Oct 25, 2009 | Jura Capresso Impressa S9 Coffee...
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
196 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
