Question about Toshiba Satellite M105-S3001 Notebook
Removal of bios level password
I'm using a toshiba satellite m105. i was using it when a blackout occured. after that incident, whenever i start up my laptop, a blue rectangular screen appears asking me for password. i didn't set any password at all for my laptop.
    President:
  • 2,961 Answers
Some laptops are passworded default at'oooo' or 'ooooo'. The bios re-set is the 'JBAT1' terminal, from jumpers 1-2 to 2-3 for a few seconds and then back to 1-2 again, but where the terminal is exactly on your motherboard i do not know. You may also try removing the bios didc shaped battery for 15 minutes or so, then replacing.
Posted on Jan 07, 2007
Bios password issue M105-S1021 I see that the Wireless card is under a small door on the back of the unit. Is there a jumper I need to short and which one. I get a lot of different solutions I was...
To reset the BIOS password read the information from this link.
Because it is under warranty the easiest method would be using software from Hiren's Boot CD.
Oct 23, 2010 | Toshiba Satellite M105-S1021 Notebook
I have a Toshiba Satellite M105-S1021. When it boots up ask for password. I do not have any password. How can I get in it?
Hi
That would be the BIOS password is open the ram compartment and pull up the plastic sticker or whatever you want to call it between the motherboard and the ram. There is a jumper called "CMOS_CLR1" use a screwdriver to short out the pins and it clears the CMOS.
Jan 08, 2010 | Toshiba Satellite M105-S1021 Notebook
I would like to reset the bios password on a Toshiba Satellite M105-S3004
Find your original sales-receipt, and telephone Toshiba,
to show that you have proof-of-ownership.
You cannot "reset" the password -- nor can a thief who has stolen your laptop -- this is for your own protection.
Dec 08, 2009 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3041 clock problem
Chances are your CMOS battery is dead, it can be replaced inexpensively if you do it yourself. After taking the laptop apart, locate the battery, it looks like a large watch battery. When you remove it, note the battery type and run to your nearest battery store for a replacement.
Jul 07, 2009 | Toshiba Satellite M105-S3004 Notebook
Cant get pass bio screen on satellite m105-s3084 toshiba
The Toshiba BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work. There is a hardware hack solution (a dongle) to remove the password.
Buy a 25 pin male D Sub connector and join the following pins together by soldering wires to these pins. Make sure the wires do not short against each other. The pins are numbered on the connector.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle into the printer port of your laptop and power up the laptop. Press F2 function key to get into the BIOS and then remove the password. Your laptop should boot up without the password and you can remove the dongle.
Feb 10, 2009 | Toshiba Satellite M105-S3084 Notebook
Bios password
If removing the ROM battery (for a period of time, perhaps about 24 hours) does not help (and many people report it does not), you may need to take it to an official Toshiba distributor who will help you get past the password after you confirm that you are the legitimate owner of the notebook.
There is a reason for putting these controls on computers: it makes life difficult for laptop thieves, as it should. I only wish more manufacturers would do this. In the future, it would be nice if manufacturers allowed owners to verify their ownership (which they previously registered during machine initial system startup) online through a form, then download a file to a USB thumb drive that could be inserted during boot to allow the option of resetting (or unsetting) the BIOS password.
The following may not be very helpful:
http://www.uktsupport.co.uk/reference/biosp.htm
Nov 09, 2008 | Toshiba Satellite M105-S3041Notebook
Bios password reset
from the Toshiba support site
The BIOS and Supervisor passwords cannot be removed or changed unless you know the existing password(s). If you forget your BIOS or Supervisor password, you will have to have the password removed by a Toshiba Authorized Service Provider. Although the prompts for these two passwords have the same appearance, the passwords are set and removed differently. If both are set, the Supervisor password takes precedence.
I assume that the notebook will have a BIOS battery similar to a standard PC. If you are happy to disassembe it you may be able to reset the BIOS by removing the battery and/or locating the bios reset jumper
Another alternative is to If this doesn't work or you dont want to disassemble the PC, you can try to build the Toshiba Parallell loopback.
A lot of Toshiba computers remove the password when you boot it up with the loopback connected
It can be made out of a 25pin male connectors (db25). Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25
Jul 12, 2008 | Toshiba Satellite M105-S3004 Notebook
BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
May 03, 2008 | Toshiba Satellite A105 Notebook
Password needed
Hello nic208, The problem is you have a BIOS level password installed. Laptop owners and computer departments sometimes install them in case the laptop is lost or stolen to prevent unauthorized users from gaining access.
Jan 06, 2007 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3001 Notebook Logo
244 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
