Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
I have a celera tv that wont program in
All i have is a blue screen. i have it hooked up to cable but when i program it for cable it goes to erase. i have the remote that came with it but unfortunatly no booklet any more. i cant find a phone number for the company. can you help.
Thanks,
Janice
See if the remote has any codes for Apex they may work for you.
Posted on Nov 26, 2008
Our screen turns blue and goes to new devices input. We have nothing else connected to tv except Brighthouse cable box. If we push the exit button on the tv remote it then goes to showing a cable box and...
Your TV probably has multiple "inputs" (coax, HDMI, component, et cetera). Use the "input" (or "source") button on your TV to cycle through all those available "input" streams.
If you select "coax", and there is *NO* coax cable connected to the back of the TV, you *WILL* see the "blue-screen". Select a different source that is "active".
Feb 24, 2015 | Televison & Video
I have hooked up all cables correctly however when i attampt to record of my xbox i get black and white record screen ive tried 3 diffrent record program im using the HD componet cable (blue green and...
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
http://www.pinnaclesys.com/presskits/Dazzle/DazzleDVD_Recorder_ReviewersGuide_May06.pdf
Good Luck, Mikeywaf
Mar 03, 2011 | Pinnacle Dazzle DVD Recorder
There is a red key on my celera tv screen, sound works but hsve no picture
There is a red key on my celera tv screen, with sound but no picture i got a rca remote for it
Jun 18, 2009 | Philips Televison & Video
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Element FLX 3210 not scanning for cable channels
YOU HAVE A BAD TUNER OR RF INPUT. IF YOU CONNECT THE CABLE TO THE VCR AND THEN USE THE VIDEO OUTPUT OF THE VCR TO THE VIDEO INPUT OF THE TV YOU CAN USE THE TUNER IN THE VCR TO CHANGE CHANNELS.
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
Blue screen
first , auto program you tv ,if still the same , your tv need to re solder. if you know how to solder,. Solder the tuner the jungle ic and system ic, but be careful of short circuit.
Oct 29, 2008 | RCA F32650 32" TV
I need the code for a celera tv
I need the universal remote code for a celera K12B-C11 TV
Nov 05, 2007 | Televison & Video
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
