Question about GE JVM1842 Microwave Oven
Noisy turntable I read in a post that there was an exploaded view of the turntable mechanism out there. I'd like to get my hands on that if possible. From what I read in the posts, and from common sense and a tad bit of troubleshooting, it definately sounds like the turntable motor is shot. Thanks in advance
  • GE Master
  • 9,156 Answers
You can see exploded views and order parts here: http://tinyurl.com/gv383 The motor is reference # 42 on the drawing and parts list. Be sure to enter your FULL model number.
Posted on Jan 07, 2007
SOURCE:
Sharp sound bar buzzing
test this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Buzzing noise
follow this instruction and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZYUSVYSH
Jul 19, 2013 | Morphy Richards AM925EF Microwave Oven
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    The turntable doesn't rotate anymore
    The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
    Here is a video of how a turntable motor should sound when you rotate it by hand.
    If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
    To replace either, you need to unplug power, then remove the bottom cover of the oven.
    You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here, but if your brand is not listed, try Encompass or call them toll-free at 866-779-5835.
    If neither source has parts for your model, please post a NEW inquiry here on FixYa and please include your brand name and the full model number from the tag in or on the unit, as well as mentioning that you have turntable-related trouble.
    Oct 11, 2009 | Daewoo KOC-925T Microwave Oven
    Microwave turntable makes a noise
    Just dont listen to Mr Miller. He rambles way off subject and will say anything to feel like he is special.
    All it takes is very fist sentence where he suggests it could be magnetron bad. Geee, if that were the case your microwave wouldnt heat/cook so you wouldnt be here having a noise problem would you? Its kinda like the mechanic saying your noisy brakes could be caused by a empty gas tank.
    Cause? - could be motor that operates turntable going bad, food or something lodged anywhere in moving parts of turntable operation which includes unseen area, or moving part that is been somehow bent or moved (unlikely without impact to microwave or previous work done possibly leaving something loose).
    Solution? - I am ignorant of specific assembly of your microwave but on many you can access motor from bottom (unplug microwave first) and replace motor yourself if you are somewhat mechanical. The cheapest easiest 1st step would be clean very well around all parts and even clean any debris you find when taken apart, then recover and turn on to see. Not the likliest but its cheap and easy and you have to take apart bottom to replace motor anyway so not really much extra work.
    Mar 30, 2009 | Kenmore 62702 Microwave Oven
    Turntable sometimes works, mostly doesn't
    It sounds like you have a jamming turntable motor.
    The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
    You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
    If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    Jan 28, 2009 | Microwave Ovens
    GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
    There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
    LG over the stove model lmvm 1935
    In some cases, cleaning them helps. Lubrication is not recommended.
    To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
    Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
    My Sanyo microwave oven is six months old. The turntable has stopped rotating smoothly. Its motion has suddenly become jerky and noisy at the same time. I have given it to the vendor who sold it to me, for...
    Since it's less than one year old, it should be fully covered under warranty, as long as the problem is not due to grease or liquid spilled down into the motor.
    Nov 29, 2008 | Microwave Ovens
    Noisy turntable
    I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
    Mar 25, 2007 | De Dietrich DME112X Microwave Oven
    Microwave Ovens Logo
    71 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    vince
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
