Question about Zephyr Venezia ZVE-E30 Kitchen Hood
Eletrical problem i just received a new control pannel for my hood. prior to this, the hood lights would not work but the fan would. i replaced the control unit, but may have not hooked it up correctly. now, the lights work, but the fan doesn't. i've called zephyr, but they're closed for the weekend, and the manual and web site doesn't give me any info. thanks!
  • Anonymous Nov 28, 2007
    I have a Zephyr Venezia wall-mount vent fan. I replaced two of the halogen bulbs (only use 2 of 4 but 2 dead bulbs were left in) and they work, but the switch won't turn them off or dim them as was the case before. Any suggestions? (rmains@mainsgate.com)
I have the problem of the lights not shutting off. It just happened today about after 6 mo use of the hood. where can I get support? Where can I get a new control unit? Venezia Zeneth
Posted on Dec 23, 2007
Cabin control problems: With blower control on 1 or 2 the aircompressor runs but fan does not blow. If on 3 or 4 blower runs and air compressor shuts down. I have replaced control unit in cabin,...
Its an eletrical problem, Check the relay on the main contorl(panel fuse box) the one in under the hood, .. The relay controls the the power going to the blower I believe you will find your problem there. If not the relay directly then the eletrical connecting to that relay eighter directly in the box or the wiring from there to the Blower.
Nb. The main hot is in the box as well
Jul 15, 2008 | Volkswagen Golf Cars & Trucks
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Hi. Last Friday we had a new Kenmore stainless steel range hood installed along with a new range. Yesterday the range hood fan and lights would not work. The fan does not come on at any speed. The lights...
Some installers plug the fan/light into an outlet in the cupboard above. Check to see if that has power. Some of the outlets are behind a panel in the cabinet above and you have to remove the screws. I have seen the plugs laying in the cabinet just like they had never been plugged in. Yours obviously was plugged in but maybe fell out. If the fan/light is hard wired than you should make sure the power is turned off at the breaker box and then check the wiring inside the box to make sure it is wire nutted together and is holding. I would also check that the breaker for the fan/light is still putting out power. These last two might be a little tricky if you have never tried them. The breakers sometimes go bad but look like they are set. If the whole hood fan is not getting power it is probably time for an electrician or the people who installed to come back.
Aug 25, 2010 | Kenmore 52153 Stainless Steel Kitchen Hood
Remote control will not turn on/off fan or light. Has good battery. Where is the transmitter located on the ceiling fan?
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Nov 07, 2009 | Hunter 52" Ceiling Fan With Light And...
My ceiling fan/light can be controlled only by the remote control. our remote is not responding with the fan anymore. it has new batteries and has power, it's just not corresponding with the light/fan. it...
Turn the power off to the fan / light by flipping the breaker or pulling the fuse and keep off for 10 seconds then turn back on, it should reset the contol receiver in the fan.
Oct 27, 2009 | Hampton Bay 24002 Ceiling Fan
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Kenmore elite ranghood (series# 550) not working
unplug the unit and unscrew the bulbs. put 2 new in if they still dont work then you may have fried the control. there are usually no fuses between the control and light/fan. well i never saw a fuse between the 2.
Dec 07, 2008 | Kitchen Ranges
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Zephyr Venezia ZVE-E30 Kitchen Hood Logo
754 people viewed this question
Top Zephyr Kitchen Ranges Experts
Vish Iyer
Vish Iyer
Norman Worley
Tom Chichester
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
