Question about Philips Magnavox MWR10D6 DVD Recorder
Connecting tv to dvd and receiver
On the dvd setting we are getting dvd sound but no video. Satellite is working properly and tv is fine, but cannot get picture for dvd. Please help.
  • njrpo842 Dec 25, 2008
    I have a Samsung HD tv, JVC dvd and a dish receiver and can't make a proper connection. any suggestions?
  • 558 Answers
In setup you need to select the type of video cable you are using to input
Posted on Dec 13, 2008
I have a Panasonic TX-P42VT20 and a SCART switching box from a number of devices (2nd Satellite receiver, DVD players etc.). This works fine with my old TV, but I only get sound and no video when I connect...
I expect the new Plasma is configured to RGB or S video. Check your menu settings and adjust to whatever the old TV was set at. Composite Video I suspect!
Feb 04, 2011 | Panasonic Televison & Video
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
How do I escape from an input screen back to watching satellite tv? Screen reads first please connect all signals and antennas to jacks and terminals on the back of the tv then press the channel up key...
Looks like your set is not receiving the signal from the sat. receiver. Make sure that the audio/video cable is in good shape and connected correctly, then select the correct input on your tv. If that doesn`t work try to connect a dvd or vcr on the same cable, if that is still no go then you may have a bad audio/video cable or there is a problem with your tv set. If it does work(dvd/vcr) then you`ll have to check your satellite receiver. Hope this help. Good luck
Nov 24, 2009 | Televison & Video
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
Connecting to a Satellite reciver
I solved the problem with my DVD recorder. I attached a cable from the loop out on the back of the FTA receiver to the RF in on the back of the recorder. All I was missing was the signal from the satellite. Everything is working fine now.
Thanks
JimCee
Mar 23, 2008 | LG Televison & Video
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox MWR10D6 DVD Recorder Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
