Question about Cobra 29 LTD CB Radio
No power at radio, both inline, and lighter plug fuses good,
Is 30a fuse too big for radio?
I had one do the same thing had to replace the +and- wires just inside the case and a capacitor, the top should be broken on the top of the capacitor or maybe just bowed up it was a 1000uF. Pull the cover with the speaker and you will be able to see the problem.
Posted on Dec 03, 2008
  •  Laron
    Laron Jul 28, 2011
    30 amp is way to big 2 amp is factory.
Using cigarette lighter for air pump
It is very likely the cigar lighters circuits wiring sizes are not suitable for the amp draw of the compressor, i suggest you not use it as a power source. Buy clip leads and solder them on and use the battery as the power source. You can obtain the electrical clips from any hardware store.
Jul 23, 2012 | 2006 Honda Jazz 1.5
Hello, i had my mcb-40 mounted in my jeep and it worked well. i switched it over to my new truck and now it will not turn on. no channel displayed, no sound. i have the power and ground both conected...
First make sure you are grounded well. Second do you have an inline fuse on your power wire? If so check that it did not blow. Even if it looks good throw another 3 amp fuse in to make sure. Also make sure your power source is actually hot and make sure the fuse in the panel fuse box for your power source has not blown. Also are you using the cigarette lighter? If so make sure the fuse to the cigarette lighter has not blown. Last you can try a new power wire. If you try all of these to no avail you more than likely have a radio issue. Good luck.
Mar 04, 2011 | Maxon MCB-40 40-Channels Handheld CB Radio
Amp
you want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Mar 25, 2010 | Ultra Linear UL801 Car Amp
The radio and cigarette lighter are not working. What do I do to fix it - no fuse says radio.... We left the lights on. The battery died. We got a jump, battery charged back up, but radio and cig...
the radio might have its own inline fuse at the back some have them on the live wire in a black tubular casing , you need to get radio out of hole in dash to find this out, do same with lighter to, some have a fuse inline as well remove that and see if that has a simular thing to the radio hope that helps
Feb 03, 2010 | 2000 Nissan Frontier
I have a 05 v70 that has no power to the stereo or front cigar lighter. I have proved the stereo and that the fuses are ok. Any ideas?
I'm not familiar with that car, but you might be certain they have a proper ground. Also, many cigar lighters have a fuseable link on the back where the power plugs on. I've seen the links corrode up and quit working. You merely crimp where they attach and it will work again. Some stereos (after market) have a separate fuse inline (not only the vehicle radio fuse). You might also just change the fuse. I've seen some that looked good, but had a hairline fracture and therefore did not conduct. I hope this helps you find your problem.
Oct 30, 2009 | 2005 Volvo V70
Cigarette lighter fuse
Here is the fuse relay diagram:
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A). Source(s): http://forums.tdiclub.com/showthread.php?t=122606 fame !
Jul 07, 2009 | 1999 Volkswagen GTI
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
Cobra 29 LTD CB Radio Logo
201 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
