Question about HP Compaq WF1907 Monitor
My computer volume is not working - HP Compaq WF1907 Monitor
    Problem Solver:
  • 10 Answers
Did it stop working or has it ever worked before?
Make sure there is a cable running from your computer to the monitor's integrated speakers. It should go from a green 3.5mm output jack at the back of the computer to one the same size in the back of the monitor. If the cable is there and still no sound, double check the connection, make sure they are plugged in securely at both ends. Be sure that headphones are not plugged into the computer at the same time or audio will only come out through the headphones.
Make sure the audio is not muted. There is a mute in possibly 3 places. One spot is the application audio: if you're trying to play from Windows Media Player, make sure the audio is not muted near the slider and that the volume is loud enough to hear.
Second place is the system volume. In the Control Panel, Audio (Start menu, Settings, Control Panel, Audio component) you can check the volume and mute of the system volume.
Third location is the monitor speakers. There may be a way in the monitor's menu to adjust the volume for the speakers. Make sure it is high enough to be audible.
If all of those are unmuted and high, you might try replacing the audio cable. Also reboot the computer with the audio cable plugged in where it should be. (Sometimes high-def digital audio can be quirky). Next try plugging in a pair of headphones into the front of the computer and see if you're getting any sound through there.
Those steps should help you diagnose the problem. If not, just post back with what you found out through these steps.
Posted on Nov 25, 2008
Why won;t my volume shadow copy stay on or work?
VOLUME SHADOW COPY and sound functions have nothing in common other than both exist on a computer.
for volume icon, rt clk system tray expand button and select properties. Then turn volume on.
Sep 01, 2014 | Dell Latitude D610 P4 1.6 GHz CDRW/DVD...
Volume control does not work prperly. What causes erratic volume settings?
Dust in the rheostat (that part that controls the volume when you turn the volume from MIN to MAX); it's causing the control to be "non-linear".
Replace the computer-speakers, if you're talking about the volume-control built-in to the speakers.
Jan 23, 2010 | Audio Players & Recorders
My volume is not working correctly. I have it turned up to 100 - the highest and I can barely hear it.
Monitor volume is affected by TWO volume controls (or even three...)
1: Volume on the monitor can be set to 80%
2: Main Volume on the COMPUTER can be set to your liking.
3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
Still problems, the audio driver in the monitor is shot.
Dec 05, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Volume on computer too loud i can't find the volume control icon
go to control panel->sound and audio devices-> in volume tab see that "place volume icon in the taskbar" is checked. then you'll get your icon back in task bar.
Apr 19, 2009 | HP Compaq Computer Speakers
Cannot ajust volume
adjust the volume through computer audio properties
Feb 22, 2009 | Altec Lansing 621 Computer Speakers
Volume button
go to start menu -> control panel -> sound and audio devices. you will find volume control. or another method is just click on the volume icon which is located at the right bottom of your windows desktop.
Jun 20, 2008 | Computers & Internet
Sansa Clip mp3 player
Use the volume + (somtimes you can use REC instead) method to force the computer to recognize the device. Sometimes requires a restart of computer after your initial attempt.
Substitute "volume +" for "REC" if need be:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 28, 2008 | SanDisk Sansa c200 MP3 Player
HP Compaq WF1907 Monitor Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
