Blinking Standby Light
TV trys to come on but won't and standby light blinks in random amounts.
tv will not power on standby light blinks randomly My Sony KV32HS550 will not power on. After it sets for about 8 hours it may come on. I also tried unplugging the power from the power strip and plugged directly into wall. I was told this might reset the TV because the power strip was over burdened or old and had low voltage. It did not work..
  • 19,396 Answers
That is because the tv had detected an internal error and now it is in protect mode, unplug the power first.
Posted on Nov 25, 2008
  • Ginko
    Ginko Nov 25, 2008
    The TV is in this state because the main IC has detected an internal problem, such as a blown component, a short, a bad voltage, a faulty IC etc.
    When the fault is detected a safety switch will keep the TV off to prevent further damage, and the tv stays in standby, sometimes, depending on the model, with an error message.
    Sure, the only simple trick that you can try is unplugging the power cable, the so called hard reset.
    The rest requires a technician taking apart the TV, testing the boards and replacing the faulty component.
  • Ginko
    Ginko Nov 25, 2008
    I was checking the specs, the KV-32 is still a nice TV set , it surely worth repair, call a local, and see if it is possible having the job done under $200.
    Parts that go often faulty are the power supply capacitors, the deflection yoke and the convergence ICs.
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
Sep 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have a sony 32fs420 that trys to turn on then shuts off what can i do
TV got internal problem and goes to standby due to protection circuit activation. In protection status, standby light would start blinking in sequence with 3 seconds pause. Let me know how many times standby light blinks to find out possible problem section in your Sony KV-32FS420 TV to suggest any solution.
Thanks.
Sep 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
We had this problem, we took it back and they said something about the tubes in it, they had to give us a new one.
Jan 20, 2008 | Sony KV-27FV16 TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
