Question about JVC AV-60D501 60" Rear Projection Television
Image colors are split
All images and words are split by colors. Colors not converging. Performed alignment procedure and does not work to bring colors together. This problem originally started out as a sparatic problem and over a short period of time (few days) became a permanent problem. Would appreciate advice, and if it's a component board failure based on you expertice, then what is it and where can I get it please. I can perform the tasks. Would also like to note: I purchased this unit when stationed at the Misawa Air Base, Base Exchange in Japan in 2001. Returning to place of purchase is not possible. Nearest JVC Authorized Dealer is 40 miles away and they won't come to residence to fix because of distance. They did tell me they think they know what the problem is (I sent them a a digital picture of image) but wouldn't tell or sell me the part to fix. At 260 lbs and mere size that's just not possible. Thank you all very much in advance. Jeff
  • Jeff Smith Jan 07, 2007
    Thanks, This sure is a great wed site. fixya.
    Where is the convergence board in the unit or how is it identified in the tv? Will the STK IC's be marked as such?
    Is there more than one type of STK IC. Are they something I can by at radio shack and what your best guess on price?
    Thanks again!
    President:
  • 3,130 Answers
The board is going to cost you twice what it would take to replace the two convergence IC's on the board will cost. They are the STK type IC's. Just make sure when your replacing them, you use plenty of heat sink compound on the back of the new IC's before you reinstall the new IC's.
Posted on Jan 06, 2007
Replace the convergence board. Order it from a JVC dealer.
I have model number 60pp9202 and the screen is mostly red and green and when words come up there is like a double image
Tv have any colors lines R,G,B mis alignments,have a colors shadows picures or a 3D pictures look alike?Yes?The tv have a problems known as a convergence pictures problems,it is dead and the problems.The tv convergence board must have to be repair like replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv pictures convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 30, 2011 | Philips 55PP9502 55" Rear Projection...
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
Image is showing in all three colors
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts must be change on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Sony KP-46WT500 46" Rear Projection...
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
I've converged the image and still the colors do not quite align.
No.The 2 convergence ICS must change.U know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 14, 2010 | Panasonic PT-53WX53 53" Rear Projection...
When we turned on our set, the image has a shadow,
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Samsung HCM4216W 42" Rear Projection...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
My colors are splitting inthe picture. How do I fix?
I think you have a convergence issue. Are the colors not properly aligned - do you see multiple overlays of the same image in different colors?
If so all you need is to adjust the convergence - it should be adjustable in the user manual or by pushing the "Magic Focus" button if you have one.
Jul 30, 2009 | Toshiba 50H71 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double image on screen
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53S75 53" Rear Projection...
JVC AV-60D501 60" Rear Projection Television Logo
87 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
