Question about Seiko Lorus LO111 Watch
How do i set time alarm and stopwatch on lorus sports watch
Would like to know how to set time and alarm correctly.
  • Anonymous Feb 26, 2009
    my lorus chronograPH WATCH STOPS AFTER A FEW MINUTES
SOURCE: cannot set correct day, time, alarm on my Ohsen watch
Press 3 times left lower button, then select with right lower button what you want to adjust, then adjust with right upper button. To finish press left lower button again.
Posted on Jul 10, 2009
SOURCE: Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
Posted on Nov 16, 2010
SOURCE: how do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Posted on Apr 12, 2009
  • 5 Answers
SOURCE: columbia all sports digital watch
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
Posted on Mar 25, 2008
SOURCE: Bijoux Terner Sport watch RO616F
I got one of these on a cruise, and I had the same issue, and searched on the web just now (7/26/08 9:20pm) and could not find an answer.....so, I just sat here for a few minutes to push all the buttons...
Mine has 4 buttons at the 2, 4,8,10 positions....corresponding to "start", "reset", "mode", "light"
Hold down the "start", then while holding it down, push the "reset" button.....voila!
Posted on Jul 27, 2008
How do I set alarm on Armstrong 45/7041 watch? Did not come with instructions
A= reset
B= Mode
C= ST/STP
D= Light  (edl)
•SETTING TIME AND CALENDAR
1.For time telling mode, press 'B' three times. The seconds should start to flash. Press 'C' to zero out the seconds.
2. Press 'A' minutes will flash, press 'C' to set the minutes.(holding down C will advance the digits faster)
3. Press 'A' hours will flash, press 'C' to set hour.
4.Press 'A' date will flash, press 'C' to set the date.
5.Press 'A' month will flash, press 'C' to set month.
6.press 'A' The day of the week flashes, press 'C' to set day of the week.
7.Press 'B' to finish and it will return to the time.
IF ANYMORE QUESTIONS ABOUT SET FEATURES SUCH AS 'STOPWATCH, SPLIT TIME, SETTING 24 HOUR ALARM, ACTIVATING ALARM, OR SNOOZING THE ALARM'. FEEL FREE TO CONTACT ME @ vannabeltran8.sb@gmail.com WITH 'ARMITRON WATCH' IN SUBJECT BAR AND I WILL SEND YOU PICS OF THE MANUAL.
-Savannah:)
Feb 14, 2015 | Armitron 457004WHT Womens White Nylon...
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
How to set alarm in my sports watch
1- goto this link http://www.sportline.com/product.php?prod=22
2-download the user's manual to get instructions on setting alarm
Jan 25, 2011 | Sportline 220 Sport Timer Stopwatch ...
How to set the alarm on the lorus rf33bx9
If you put "lorus watches" into your search engine you should come up with the Lorus web site.
One of the options given is "instructions", click on this and you will be asked to enter details off the back of your watch.
Feb 11, 2010 | Bulova Watch
Cant get old watch to chime
Instructions are on the inside of the back cover: 1. short circuit AC and the battery clamp. 2. the hands will rotate once clockwise 3. in the chime mode, pull out the crown and set the hands to the 12:00 position 4. Return the crown to normal position, change to time mode and set the desired time
Jul 06, 2009 | Disney Lorus Rare Musical R2306AX Watch
Replaced battery in lorus digital watch, now the alarm won't work
The alarm spring proabably was lost. If it was, it will not alarm again.
Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
How do i set alarm on a gap sport watch?
Jan 09, 2009 | Columbia All Sport Digi Watch l
Seiko Lorus LO111 Watch Logo
1,496 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
