Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100
Just purchased off ebay a 3100 GPS unit from Magellan. Wasn't getting any satelite signal, did a reset this morning worked for about 20mins then stopped. (no satelite signal again) tried resetting a couple times and powered off/on with no change. Any thoughts
  • 53 Answers
Have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Posted on Nov 26, 2008
I dropped my magellan "maestro 3100", now it will
hi elizalde_cl
start your 3100, then get a paper clip and depress the reset on the left side near the bottom of your 3100 to reset it and let it restart. that should fix it, but if it doesnt, let me know and ill tell you what to do next.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Dec 02, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
I'm looking to purchase replacement power jack (the power jack mounted on system board) for magellan maestro 4040. where can i purchase only the jack.
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Nov 11, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My maestro 4050 stopped receiving a signal from the satelite
try the hard reset, set it out to the open sky for a few minutes (may take as much as 30 min) to acquire the sats
Jul 01, 2009 | Magellan Maestro 4050 GPS
Maesto 3100 touch screen does not work!
There is an online tutorial that shows you how to replace GPS batteries, parts are many times available though www.ebay.com. The repair manual is at : GPS Repair
Apr 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 only get logo and black bar
did you hit the reset button in that little hole on the left side of the unit?...press it with a bent straight paper clip wire and it should reset properly
Mar 24, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Touch Screen
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site
http://www.magellangps.com/support/
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
Feb 07, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Bin it - get a Tomtom.. my Roadamte 700 has had so many problems and Magellan support just don't care/respond.
Am getting a Tomtom 720T with maps and cameras preloaded - updates automatically each time you place it on its cradle attached to your PC/internet.
Dec 26, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
164 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
