My wife changed the water filter on our Amana ARS266ZBW side by side and now when you dispense water, water also coming out through wall on left and flooding floor. She has installed before and claims she did not do anything different. I dug the old filter out of the trash, yuk, and re-installed, and same problem. What happened? It was working fine before the replacement. Thanks in advance, Bob
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
SOURCE: Water Supply Line for Ice maker and Water dispenser is leaking.
Go to the hardware store and get a brass tube sleeve coupling; cut off the old tube end, slide the hex cap thread side out onto the tube, then; slide the tube sleeve onto the tube and, seat the tube into the supply valve then tighten the hex nut.
take the old parts to the hardware store to compare; the size is most likely 1/4" the part can be found in the "evaporative cooler parts" section of the hardware store
SOURCE: Kenmore side by side refrigerator water dirty
You may need to replace the water reservoir located behind the crisper. They are known to flake and cause the problem you describe. They are usually replaced with a coil of water line instead of one larger reservoir to stop the problem.
