Question about Toshiba Satellite A215-S7422 Notebook
Laptop OVERHEATING in 2-5 min!
Well if i lave the AC running under it ... it works great of course i freeze my rear off... if not 2-5 min it will shut down and be REALLY HOT!
Its really th A215-s4697 but the option for the 4697 isnt there...
thanks ahead of time!
Well i would suggest first cleaning the laptop fans, if they are clean then i would say its the fans and need replacing.
Posted on Nov 25, 2008
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
I have a 05 scion tc that the ac compressor will blow ice cold and after a few mins the compressor will kick off. If u turn the ac off for a few mins and turn it back on it will blow cold for a few mins...
may be a few things try checking the a/c lines when it does the shut off thing are they freezing up? may need a dryer. is the fan coming on at the radiator when the a/c comes on? it needs this to keep the head pressure down. does it drip water when the a/c is on under the car? may another sign its freezing up.
May 04, 2012 | 1953 AC 2 Litre
I have a 2 HP 230 V AC Pentair Challenger series pump for my pool. The start capacitor is bad; however, I am able to spin the shaft protruding from the rear of the motor upon switching the pump on. The...
Replace the start/run capacitor. What you are doing by hand is very dangerous.
Your booster, what shut it off in the past? Does this work through a independent relay that is powered by the pool pump circuit?
Talk to me ...
Thanks for your question today.
Jun 19, 2011 | Pentair 2 hp Challenger Pump
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using...
Make sure the cooling fan for the laptop is not obstructed in any way or is not dirty. It's pretty common for a laptop to get plugged with dirt from normal use. Get a can of air and blow the machine out to remove dirt, lint or debris.
You could also have a defective battery, but try cleaning the machine first.
Feb 24, 2011 | Computers & Internet
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My laptop model is acer 5738g and i am experiencing overheating issues with my laptop when i am playing games.i play a game for like 45 mins and then it suddenly shuts down.i buyed this laptop 6months ago...
Have you tried using a cooling pad under the laptop? You can pick them up at any electronics or computer store in your area. If it still overheats after that I would HIGHLY recommend you get in touch with acer and have them make sure that the laptop is ok.
if it overheats too much you will run into problems.
Mar 20, 2010 | Computers & Internet
I have a dell Inspiron 1705, it runs fine, boots fast, runs normally however after about 10 to 15 minutes of use the laptop freezes. The only way to reboot it is to hold down the power button to shut it...
Looks like an overheating problem.
First, make sure that you put your laptop on some hard surface. If you put in on your bed for example, the soft surface will block the air vent on the bottom of the laptop, resulting in poor cooling of the inner components.
Do you hear the fan working, and air blown out of the exit vent on the side (or rear) of the laptop?
If not, then perhaps the fan is broken and needs replacement.
If the fan can be easily heard, working at full speed all the time, there is a problem with blocking the air inlet, or the internal radiator/heatsink got covered with dust and lint, and needs cleaning - try compressed air blown from the opposite direction (from the air outlet) to blow away the dust - of course with the computer switched off, otherwise you'll be "fighting" the fan trying to blow in opposite direction. If this doesn't help, the laptop needs servicing, as it probably lost the heat-conductive layer between the processor and heatsink.
Jan 23, 2010 | Dell Inspiron E1705 Notebook
Toshiba sattllite a 60 has heat problem
You have an option here to check what the problem is....first I would like you to get a can of compressed air from an office supply store that is used for blowing the dust out of electronics. Blow the dust and dirt out of the vents on the side, bottom and rear of the laptop. I then would like you to run the laptop on the AC adapter only to see if the ac adapter is the problem. So take the battery out and run the laptop just on the AC adapter. If it shuts down, put the battery in and remove the AC adapter....if the machine continues to operate, the problem is AC adapter. It is most likely failing after a period of time causing an unstable power source and sgutting the laptop down....or if it fails on just battery too, then I would take off the panel access door to the processor and heatsink, remove the screws to the heatsink and carefully remove it and check that there is a layer of "thermal grease" on the two processor chips. If not, get some thermal grease and apply a very small amount and spread it evenly on the chip surface. Replace the heatsink and try to power it up.
Sep 15, 2009 | Toshiba Satellite A60 Notebook
WII KEPS FREEZING PLZ ANSWER
Most likely, your system is overheating. Make sure you have several inches of space all the way around your system (except of course underneath it) and that it's not in an enclosed space. The system will shut itself off to keep from breaking. Good luck!
Jan 04, 2009 | Nintendo Wii Console
Toshiba Satellite A215-S7422 Notebook Logo
249 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
