Question about Hotpoint WMA74 Front Load Washer
FRONT CURCUIT BOARD HAS BLOWN.
I HAVE SEARCHED DOZENS OF WEBSITES EVEN HOTPOINT OFFICIAL SITE AND CANT GET A NEW ONE ON ANY OF THEM. CANT FIND THE SAME MODEL NUMBER ON ANY OF THE SITES. CAN U TELL ME WHAT ELSE I CAN TRY 2 GET THE PART I NEED PLZ.
  • 135 Answers
Try emw electronics web site. Never let me down yet..
Posted on Nov 26, 2008
Washing machine has blown a fuse and tripped the curcuit breaker
I hate to say this but a blown fuse in that machine wouldnt trip the breaker, so if you turn the breaker on and it stays on until you start the machine the motor is probably shorted and need to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Hotpoint First Edition WMA22 Front Load...
Hotpoint ultima extra washing machine, door open sign flashing on lacd display even though the door is closed properly
first check all connections on circuit board are tight if ok change interlock,if problem still persists you have a circuit board fault which could have been caused by blown interlock
Sep 08, 2011 | Hotpoint Washing Machines
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
Our Hotpoint front loader wont work We managed to get the clothes out, but it wont start new cycle We need a technician in the western sub's Melbourne to fix bridgey@austar.com.au
hi try changing motor brushes (carbons).... if they ok check pump filter and test with volt meter on heating element on contonuity test.it should be in curcuit..
Jan 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Lenovo J115 with new Gigabye motherboard - case fan set up
Lenovo's web-site: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
should have the information.
What connectors are leading from the front-panel?
One "clump" of wires and one connector, or several separate connectors?
May 27, 2009 | Lenovo 3000 J115 (7387-A11) Desktop...
I have an hotpoint aquarius washing machine. I think the front panel board has blown do you know where i can get a replacement for it cheap.
You won't get a new board cheap, unless it is a second hand one,not recommended.
Apart from which, the board has blown for a reason, usually caused by a faulty motor, so if you bought a new board, chances are it would blow again
Long term , probably cheaper to buy a new m/c.Your only other option is that if the m/c is under 5 years old, you should be able to get it repaired under the 5 year part guarantee, you pay for labour and call out.
Plz rate my solution.
TThanks.
Dec 29, 2008 | Washing Machines
1.5 amp fuse on main powerboard blown
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 19, 2017 | Televison & Video
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wmm39a
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Dec 08, 2007 | Hotpoint WMM39 Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
57 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
