SOURCE: need wiring diagram for 1992 ford taurus 3.8 ccrm
autozone.com has online repair manuals with wiring diagram check it out
SOURCE: horn wiring on kh laser
It could be that the horn needs to be replaced or a fuse or a relay not working also check the horn button on steering wheel, but start with the fuse first then check the horn by wireing it directly to battery [this willbe noisey]
SOURCE: radio code
I had the same prob. you will have to take it back to dealer to get a new code. Can be expensive. Shop around for a fiesta radio / 6 CD stacker unit already with a code. Mines out of a '98 fiesta into my '85 Bronco ! Stacker unit fits under passengers seat, cable back to dash via under carpet. Mine was cheaper to buy (from a wreckers) and install my self than the dealers costs to get the new code for an old unit. on-line wiring diagrams avalible.
Cheers !
ozzy
SOURCE: Need Valve clearance for '93 kh ford laser
0.10 - 0.15mm inlet
0.18 - 0.23mm exhaust
but you must be carefull because the top of the valve seat becomes concave from wear, a feeler guage will not give the most accurate reading, hope i have been of some hel
SOURCE: 1992 ford escort wiring diagrams
I have the instrument cluster diagrams, need an email address to send to in pdf format
