Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Throttle and brake both in locked positions (hyrdostatic)
48 inch hydrostatic husqvarna...went to lock the foot brake in order to empty bag catchers....got back on and all of a sudden foot throttle as well as brake pedal both in locked positions. Can not seem to get either unlocked. What could be the problem?
Took out the first cotter pin in the cruise control rod assembly (starting from top) and freed the lock body by hand. Everything is back to normal. Posting solution for future reference.
Posted on Nov 26, 2008
How do I change the throttle handle on a JD D140 mower?
Loosen the cable clamp at the linkage at the carburetor and remove the cable end from the linkage. The throttle lever housing has 2 locking tabs on both sides. You might have to use a screw driver to depress the tabs. While depressing one tab at a time push the lever housing up until removed.
Jul 01, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
HYDROSTATIC TRANSMISSION NOT WORKING ON NEW MOWER
there is a rod on the rear of the mower that is pulled back and lock into place this is there to push the mower around when not running it just lift the lever up and it should pull in then your ready to go
Sep 02, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I started my ride on and it will not go forward or in reverse at all.The lock is off so it should be working..any ideas?
if you scroll through these lawn tractor questions, you will note a lot of failed hydrostatic transmissions in the husqvarna line. seems like that is the prime suspect in your problem, if the drive belt is good. i had one and the transmission failed after about 5 years, but I see many with fewer years of wear
with the same problem. a new transmission costs about half of what a new tractor costs. these are actually made by the AYP company which pays a licensing fee to husqvarna to use the name. AYP makes most of the mower lines you see in stores. my neighbor has a craftsman with a bad deck which seemed identical to the husqvarna, except color. However when i went to cannibalize his transmission it was completely different and would not bolt into mine, so i went out and bought a simplicity.
Jul 27, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Husqvarna YTH2242, the engine runs great but as soon as I take my foot off the brake the engine dies. What can be the issue?
all the safety switches tie into a relay which kills the motor if they are not in the correct position for operation. find the relay and replace it.
Apr 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The back wheels want go cause somethings locked how do i fix that?
the hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Mar 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Brake will not release on my Husqvarna riding mower
the brake caliper is rusted closed causing the pads to stay enguaged, dissasemble the brake caliper and remove the 2 pins and de-rust them with emory cloth. reinstall them with anti-seze and reasemble the brake caliper back onto the transmission should be good to go!
Aug 29, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
310 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
