WONT SPIN Washer washes and fills and drains properly however when it comes time to spin it continues on as if it were washing. Ie it tumbles one direction then the other but will not spin. Door swwitch checks out and detergent tray closes properly. I suspect either the timer or the motor control module but don't know how to determine which one it is.
  • 72 Answers
Check the connectors from your control knob, sometimes they come disconnected and or short out, but the problem is most likely as you said in you motor control module, it's malfunction sounds like an electrical problem as well check all conncections/wires...hope this helps let me know if anything changes
Posted on Nov 25, 2008
  • Washing Mach... Master
  • 19,396 Answers
It can be a problem with the motor couple, or a bad bearing.
  • Ginko
    Ginko Nov 25, 2008
    I would restrict the diagnosys from Repairclinic.:
  • The motor coupler may be broken. Many
    Whirlpool®-manufactured washers use a small, relatively inexpensive
    motor coupling. It's plastic and rubber and is mounted to the shaft of
    the motor on one side, and to the transmission on the other. Over time,
    the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one
    or two belts. If a belt is broken or badly worn, you need to replace it
    with a genuine belt from the manufacturer. (Some washing machine belts
    are designed with special characteristics not found in automotive
    belts.)
  • The clutch may be worn. If your washer is a GE, it may
    use a clutch to come up to the proper spin speed. As the clutch wears
    out, it may prevent the unit from spinning well or at all. If the
    clutch is worn, you need to replace it. For this job, you probably want
    to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands
    use a reversing motor. For agitation the motor runs in one direction,
    for spinning and draining, the other. It's possible for a motor to burn
    out in one direction and continue to operate in the other. If this
    happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older
    washers produced by Whirlpool® have a transmission with an
    electro-mechanical shifter. If the shifter becomes even partially
    defective, the unit may drain the water but not spin. This is a complex
    system, if your washer has a shifter problem, you may want to hire a
    qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or
    seized. These components allow the inner tub to spin freely inside the
    outer tub. When this is the problem, you usually hear a loud sound
    during the spin cycle. Call a qualified appliance repair technician.
  • Additionally, some models have an electronic module called Motor contropl unit, that may be faulty.
    Check particularly driving motor, motor coupler, motor control unit if present.
    If this is a belt model, replace the belt.
  • 13,433 Answers
it doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Will not run wash properly
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint WMA50 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Jun 08, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Open Questions:
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
