Question about Curtis Lifestyle DVD System
Curtis 5.1 Home Theater System
I received this and am trying to hook it up to a TV/VCR/DVD combo set. All speakers plugged in, master component plugged into TV, and still get no sounds through the speakers.
  • 4 more comments
  • Btanna Nov 28, 2007
    I am trying to hook up the home theater system to the tv so that i can watch tv with the speakers to.
  • Anonymous Dec 27, 2007
    I bought this as a christmas present I did get sound but it was very weak and only through the first to speakers the only directions is a diagram with lines which is ridiculous... hmmm not sure what to do am at a loss of actions to take Ive bought new wiring changed many connections and stil nothing. with good quailty.
  • Anonymous Jan 01, 2008
    Can PS3 be hooked up for surrond sound? If so, please advise.
  • Timothy Prescott
    Timothy Prescott Jan 04, 2008
    We bought the Curtis DVD home theatre system we have sound while playing the dvd's but none when trying to watch tvwhy? Is this just a DVD system and not a home theatre system?
  • squarebutte Jun 05, 2008
    I have three Curtis dvd players, one a home theater 6041 and two portables 8017. the home theater and one portable both worked well for several months then gradually started saying "bad disc" although the disc had worked previously in the same systems. I have unplugged both as per a previous post to someone else but that did not work for the home theater. I can not find where my girls put the other non-working player.
    Any suggestions? Thanks in advance
  • Anonymous Mar 16, 2014
    Da646pa awa conection to tv sound settings aux cords dvd player picture no how to audio surround sound system plugging plug speakers on on on
THE VIDEO NEED POWER FOR THE TV TO SEE THERE IS SOME THING THERE
Posted on Apr 26, 2009
Can it hook up to the cable and have the sound can out the speaker when wacth tv . so one can here it with not be so loud for the for any oneself,in the roon with then .
Posted on Jan 14, 2007
SOURCE:
Xbox360 not hooking up to Curtis DVD5091 surround sound through optical cable
try running the optical cable from your dvd directly to your tv and then select whichever input (eg HDMI 1/2 etc) you use to play the xbox on..In theory this setup should allow any audio playing on the tv to go through the surround sound..hope it works
Feb 11, 2013 | Curtis DVD5091 Theater System
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
Cannot get any sound from the speakers when just watching tv do i have it hooked up wrong
There are NO audio or video inputs on this device, so how would TV-audio get into it for amplification? It's NOT really a Home Theater System, but a DVD player with speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Curtis-DVD5091-Home-Theater-Systems-review-manual/id/19508dj283/t/1-2/
Feb 26, 2011 | Curtis DVD5091 Theater System
Curtis DVD 5091 Home Theatre System
I believe I have the solution....but it depends on your dvd player's zuxilarily capabilities. Do you have a second set of OUTPUT plugs that are colored Red and White on the back of the TV? Do you have a separate Red and White INPUT plugs on the back of the dvd? The TV must use the speakers in the DVD system by pushing the sound OUT. You cannot accomplish this if the dvd is only pluged into the INPUT of the tv.
\Another option is o make sure your DVD player has a "auxilary" or separate input channel on the console or remote.
I have a DVD home theatre system as well, not the same brand, but that shouldn't make a difference . Its a matter of how the sound is received.
Hope that helped.
Apr 29, 2009 | Curtis DVD5091 Theater System
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
I have the RCA RT2500 model and I am looking for directions to connect tv, DVD, gaming, Cable Box, etc are there anywhere on line I can find it? thank you
the back should have a squared in box around the inputs like dvd vcr sat tv cd, dvd and sat have svideo and component a/v plugs, the vcr just has component rca a/v ports, tv and cd are just for audio, then you also have the option to hook up optical for dvd and sat. just plug your vcr into the vcr box and hook up svideo or the yellow monitor out plug to your tv, hook in the speakers and turn that baby up.
Jan 07, 2009 | RCA RT2500 System
I can't figure out how to hook up a wii to a home theater system
On the back of your AVR (audio video receiver) where you connect a DVD, VCR or any other component. Example if there are open component jacks where you would connect a VCR just plug in the Yellow, Red and White cables. Turn your AVR to the source you connected to and turn on the TV. It should then play thru the speakers and be seen on the TV. Treat it just like a DVD player or any input source.
Dec 31, 2008 | Nintendo Wii Console
How do I hook the tv up to the speakers?
we had to hook sound cables from DVD player into digital cable box, not tv and now surround works in tv mode as well as dvd.
Dec 26, 2008 | Curtis DVD5091 Theater System
Installation help
Hi daddi....could you please update your post to include the entire specific model number of your TV and I will be better geared to offer you comprehensive steps without errors.
Aug 02, 2007 | Curtis Lifestyle DVD System
Curtis Lifestyle DVD System Logo
816 people viewed this question
Top Curtis Audio Players & Recorders Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Joaquim Martins
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
