Question about Refrigerators
Cannot Remove the Catch Tray in the Fridge Door for Cleaning
I have a Roper/Whirlpool side by side fridge with through the door ice and water. On the outside of the macine, below the ice and water dispenser there is a small catch tray for water or ice. The tray gets dirty from time to time and I cannot figure out how to remove it to clean it properly. Can you help?
  • dmellen Nov 28, 2008
    Thanks a bunch.....I tried prying this thing out but never guessed it would slide straight out!
    Sergeant:
    Champion:
  • 311 Answers
It pulls out. Please leave feedback.
Posted on Nov 28, 2008
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
I PURCHASED A WHIRLPOOL GS5VHAXWY FRIDGE AND THE ICE IS NOT COMING OUT OF THE DISPENSOR WHAT IS WRONG WITH THE ITEM
first thing to check is that you have water going on the inside of the ice maker tray simply stick your finger inside and see if there is water if there is no water you would then look at the water valve or the line in the back of your fridge if there is water or rather there is ice inside the tray you would want to remove the ice maker and run the tray under hot water then reinstall to test if this does not work then replace the ice maker hope this helps
Jul 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
WHIRLPOOL MODELED5VHGXML10 HAS WATER RUNNING FROM UNDERNEATH
is it over flowing on floor ? the pan is the one under fridge on the out side ? it should be full but not over flowing.
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Gold Ice dispenser problem
i had same exact problem, i search over and over for solution. I even change the auger moter.
here is the solution for this particular problem.....
with the fridge door closed, remove bottom catch tray under ice dispenser revealing two screws, take off screws and slide front trim up to remove, you will have to unplug switch on trim to fully remove, look in top right corner there is black switch the will most likely be loose, this switch is your problem, mine was basically dislodged and the ice dispenser lever was not making contact, i simply zipped tied and siliconed the switch back to its respective place. if yours is making a good connection then the switch its self must be bad, you can test the switch by using the switch from water dispenser side...
i hope this helps
Jul 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
381 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
