Question about Ovens
Can't figure out how to change the light bulb in the oven
Light is in the upper rear right corner of oven.
it appears to have some sort of cover over the bulb.
How do you remove the cover to replace the bulb?
  • 1 more comment
  • Anonymous Jan 25, 2009
    I cant get the oven light out to replace it, I pushed , pulled turned
  • Anonymous Mar 16, 2014
    I cannot seem to get the oven light bulb cover loose. Is there something special needed. Manual says that it just unscrews, but I can't get it to budge.
  • Anonymous Mar 29, 2014
    Cannot remover bulb cover/diffuser on Miele oven
    President:
  • 1,462 Answers
Normally the cover just unscrews but may be difficult if not removed for a long time - large pair of grips will help
Posted on Nov 26, 2008
  • richards934 Sep 20, 2010
    A 14" pipe wrench had wide enough jaws (1") and fit straight over the cover. 1/8 of a twist and it was free. The best (safest sounding) suggestion I've seen: is using a 4" strap wrench from Home depot .
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Can't change the bulb in o ovenneff
If you are struggling to get the lamp cover off in the far right top corner, try wearing a pair of rubber gloves to get a better grip and you need to turn it right to left ad you look at it, if it still will not move, contact Neff Customer Service and they should sent you out a removal tool free of charge 0844 892 9002
Nov 21, 2011 | Neff B1451 Single circotherm plus Electric...
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
How to change the oven light
jenn air usually hides the model number good lol if you open the door on the outer face of the oven might be a little grill where you can see inside and your model might be in there or it might be around the warming drawer if you have one
you need just a regular appliance 20v light bulb you can get at home depot or hARDWARE STORE  if you open the door on the back wall on the left or right upper hand side there is a glass bulb looking object , the material is thick glass/ plastic that just screws off lefty loosy right tighty once that is off you have access to the light bulb
if there is a little wire in front of the thick glass/plastic object just pull it up or down dont unhook it or break it off
Jun 07, 2009 | Ovens
Whirlpool Super Capacity 465 oven can't figure out how to change the lightbulb and it is not listed in the owners manual. Can anyone tell me how to remove the lightbulb cover?
The glass lens cover for the bulb is usually screwed into the socket so turn it counter clockwise and see if it comes off. When replacing the light bulb, press the door switch to ensure no power is going ot the bulb socket to prevent it from damaging the new bulb.
Mar 07, 2009 | Ovens
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Unable to take out light bulb
I can tell you it screws out . i had to break mine to get it out ( the bulb cover that is) Still had some thread left to wind back up.
Dec 22, 2008 | Ovens
Ovens Logo
1,162 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
