Question about Durabrand PDV-705 Portable DVD Player
Color bar locks on black and white - Durabrand PDV-705 Portable DVD Player
    Problem Solver:
  • 22 Answers
This is probably a bad or stuck switch on monitor board.
Posted on Dec 29, 2008
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
How to print pdf file in black and white. I went to print --> properties. but there is not options. I am using adobe reader 9.
There should be an option to print grayscale in properties, but if it's a color PDF it could be locked so that you can't change the properties, look for the lock symbol in the top bar when the pdf is open.
Jan 10, 2010 | HP PSC 1210 All-In-One InkJet Printer
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Need to print with black cartirdge only.
just try to print a black and white, you can do that when you print a document. There is a window that will pop up about to print, click on properties just beside the ame of your printer and go to paper/quality bar menu there you should see a choices between color and black&white. Just choose black & white and try printing.
Jun 22, 2009 | HP LaserJet 2840 Printer
HP 5550c Printer: install a toner cartridge and now the cartridge is jamed and unable to turn the toners as before. can not remove the cartridge.
The white plastic lever has broken and needs replacement. On the bottom left hand side bracket of the Transfer kit to it's left is a black plastic cover which pops off remove it and you will see a white plastic
lever which pivots on a bar with the transfer kit locking and unlocking the toner cartridges it often goes bad and tears. Hp should modify this and make this piece metal not plastic. You can manually pull and push down on the metal bar to lock unlock the toner cartridges for a temporary fix.
Mar 10, 2009 | HP Color LaserJet 5550hdn Printer
My HP officejet 6110 only prints in black and white
Every time I try to print I get a message saying that The Spooler service is not running, what should I do?
Feb 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
No color
CHECK THE SYSTEM IC
Sep 06, 2008 | Akai CTS2550 25" TV
Residential Electrical Wiring Current NEC
On a 120/240Volt single phase system is:
Black = 1st phase
Red = 2nd phase
White = neutral
Green or Bare = ground
3 phase is the same with the third phase being blue.
Jul 28, 2008 | Motorola 3-Wire Surveillance Headset...
1995 Chevy Blazer Wire Color Codes
95-97 blazer or 94-97 S-10
12volts red (there will be 2)+ ignition harness
Starter purple or yellow + ignition harness
Ignition pink + ignition harness
Second Ignition white or pink/white + ignition harness
Accessory orange + ignition harness
Power Lock lt. blue + either kick panel
Power Unlock white + either kick panel
Lock Motor gray drivers kick panel
Unlock Motor tan drivers kick panel
Parking Lights+ brown switch or rear harness
Door Trigger white - keyless module
Dome Supervision use door trigger
Trunk/Hatch Pin tied in with doors
Trunk/Hatch Release black/white + switch or keyless
Tachometer white AC ECM
Brake Wire white + at brake pedal switch
Parking Brake black at the pedal
Horn Trigger black - steering column
Jun 13, 2008 | 1995 Chevrolet Blazer
Durabrand PDV-705 Portable DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
