Question about Kitchen Ranges
Some air blows downwards from rangehood
My rangehood has 2 centrifugal fans with 700 cfm. It blows some air downward. When connected to the duck work, it blows more downward. What's wrong with the vent?
    Sergeant:
    Champion:
  • 338 Answers
Clog? or the shutter on the end wont open.
Posted on Dec 07, 2008
Should ceiling fans work "forward" or "backward"
During the winter you want the fan to blow downward so that the heat that collects at the ceiling is circulated,
Nov 20, 2010 | Universal Remote Control Hampton Bay...
Fan is running in reverse, how do I change it to blow downward?
if it has a remote for it, there should be a reverse button on it. if not, get a step ladder out, and look around the fan for a switch. if you find one, switch it the opposite way.
Aug 12, 2010 | Minka -Aire Brushed Nickel Remote Control...
I know I should reverse the direction of the ceiling fan for summer/winter. Which way is which?
you want the fan to turn anti clock ways in winter as this sucks the cold air upwards pushing the hot air from the roof downwards. and clock wise in summer blowing cool air downwards to cool you
take care
please remember to rate this repair.
Aug 03, 2010 | Craftmade International Craftmade...
2003 trailblazer I have no heat or air coming out of my dash vents
Is it no heat/air when sitting still, or no heat air period? If the heat and air blow slightly when driving you have a bad blower mower/resisitor and its not allowing the air to blow into the cab. If not blowing period when moving probably bad heater controls or fuse... Worst case scanario is you have an electrical problem that needs to be diagnosed
Jul 15, 2010 | 2003 Chevrolet TrailBlazer
We have 10 hp Motor with centrifugal fan fitted with 5 TR Cooling compressor? We want to know the cfm of air?.
You need to either get the specifications from the fan manufacturer, or take air readings with a manometer or flow hood
Apr 27, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Had a ceiling fan with dual purpose, one to blow air upwards durng the cooler months and one downwards during warmer mos. unable to set the fan to blow air downwards.
Explain set it. Generally there is a switch on the fan to reverse, are you attempting reversing by that switch or a wired in wall switch? If it runs in one direction it will run in the other. Something in the control is broken or not wired correctly.
Sep 16, 2008 | Heating & Cooling
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Jul 30, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Kitchen Ranges Logo
405 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
