Question about Planar PL2010M 20" Flat Panel LCD Monitor
I need to replace the external power supply on my Planar PL2010M LCD monitor. It is the type that has a standard AC cord that goes into a box and outputs to a single DC Jack. I can not find the specifications for the output (Volts/Amps/Watts etc) nor the size of the output prong to have a new one built. Can anyone help me with this? Are there any less expensive alternatives to purchasing a new one ($70) from Planar website? Any help would be appreciated. Thank you. xtreme
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Posted on Jan 07, 2007
I have a broken PL2010M. The back shows the power requirement as 12V DC, 6.67 amps. The polarity is not indicated, but appears to center pin positive. I'm looking for a replacement inverter, if you hear of one.
Posted on Jun 25, 2007
Thank you for the lead. I'm trying to verify whether that power supply works on the specific model that I have or not. (No there weren't any markings around the power supply plug-in) The Viewsonic adapter works on the 19" Monitor, but the 20" and 21" appear to use new (and very different) power supply options. I'll follow up on the lead though and see if I can find someone who can verify that it will work on the PL2010M. Planar's lips are sealed! Thanks again.
Posted on Jan 08, 2007
Feb 27, 2011 | Envision EN 9110 19" Flat Panel LCD...
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 05, 2011 | Planar PL2010M 20" Flat Panel LCD Monitor
Nov 09, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
Jul 24, 2010 | Hyundai ImageQuest B90A 19" LCD Monitor
Jun 06, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
Nov 22, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Oct 08, 2008 | Televison & Video
May 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Jan 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Nov 25, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
255 people viewed this question
