Computers & Internet Logo
Posted on Nov 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen not displaying windows info. moving it about sometimes works
jason
Level 3:
  • Master 905 Answers
  • Posted on Nov 25, 2008
jason
Master
Level 3:
Answers
905
Questions
8
Helped
320948
Points
2511
You have either a broken wire in the monitor connection or a bad connection at or in the computer
When I play any youtube video I get two screens one above the other
Are there same content in both windows or some links to other web sites in one of the window? In that case, the stuff in one window may be some advertisement or some stuff the uploader put there for you to see as reference content. Can you move the page a little bit and see whether one of the window disappear? Sometimes there may be a memory issue so the refresh of the screen isnt working so smoothly but it will force it to redraw the window by moving stuff or adjust the resolution rate of the screen which you can do in the display settings.
1helpful
4answers
Radio/nav system dead
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
I bought a computer gateway dual core and I plug it to a CRT but the image that is displaying is not complete is like the screen does not fit the monitor how can I setup to get the complete image on the...
control panel - display - settings There is a slide bar on the lower left. slide it to the left and click apply. That will change the size of the display so all you need to do is find out what you like or what the 'native mode' is if you have a lcd monitor. That is the display size it want to have and should be show in the manual.
You may also want to click on advanced which will be to the right of that slide and then makre sure the display adapter has the right drivers. You may want to download and install the drivers directly from the manufacturers website. sometime windows update will install a update and it just doesn;t quite work so best to get the one from the factory if that is the case. Also make sure the monitor is in there correctly. Most major brands will let you download a inf file and make sure the only selections available are those that the monitor can safely handle.
1helpful
Screen does not display images/camera will not take pictures
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Blank screen when moving windows
First, check out this link -- http://www.pcguide.com/vb/showthread.php?t=25482 That board is known for bad caps, the link will show you what to look for.
2answers
Black Box
i had the same problem with my rca truflat.. i read from a posting of a similar problem with a different tv brand to switch your closed caption options 'off' or set it to a 'cc' option instead of the 't' options.. (this was done through the on-screen menu..) i gave it a try and it worked for my tv.. hope it works for you..
Grand Canyon Tech
Grand Canyon Tech
