Question about Maytag Neptune MAH5500B Front Load Washer
Door lock how do i change the door lack?
    Sergeant:
    Champion:
  • 291 Answers
You take the 2 screws out on bottom of front and raise bottom and lift out ,,, two 5/16" screws hold top down ... take out and raise top, it right there and held in by 2 screws / if you need one let me know and i will see if i can help.
Larry
Posted on Nov 25, 2008
1998 GMC Jimmy, 5-dr......didn't pick up yet. Changing locks, How many door locks? Driver door n tailgate, so 2, others? Yes, I'm a girl so forgive my lack of mechanical skills, lol.
don't change the locks yourself or you will wind up with all of those extra keys
get a locksmith to sell you keyed alike locks so that you will only need one key to open all doors
Jun 16, 2017 | GMC Cars & Trucks
Door key will not open door
Will door key insert into lock cylinder? Usually exterior door lock cylinders may seize due to lack of use if using the key fob. You can use WD-40 and insert the straw into the lock and spray liberaly. Use the key in a sawing motion while applying turning pressure on the lock. This will normally free up any seized/sticky wafers in the lock assembly
Dec 29, 2015 | 2000 Mitsubishi Montero Sport
How to open doors on 2000chevy malibu battery dead?
The outside door locks/trunk lock will most likely not work due to the key not being able to be inserted/turned in the lock cylinder due to lack of use. Spray WD40 into door lock cylinder using supplied straw and insert key until it goes all the way in using sawing motion. If lock cylinder still will not turn continue sawing motion with key while holding gentle turning pressure on the key. This will usually free up any sticky/seized lock cylinder wafers and allow the cylinder to turn
Nov 29, 2015 | Cars & Trucks
2003ford f250 Central locking lacks enough power to operate all door locks
You actually have enough power to operate the locks, but you have a bad actuator. I'm not sure where the actuator is on your truck, but go for the actuator getting replaced and you are good to go.
Jan 01, 2015 | 2003 Ford F250 Super Duty Crew Cab
2001 FORD GALAXY THE CENTRAL LOCKING ONLY LOCKS THE DRIVERS DOOR WITH THE KEY
Check wiring at driver door between the body and the door , the boot feeds power back and forth from the car to the door including your driver door speakers ,open the boot you may see that there are several or may be one wire broken , fallow colors and reattach using electrical tape . Good lock , some vehicle would require you to remove the door out the car , due to lack of space . I you have small hands you coul get lucky ,
Jan 15, 2013 | Cars & Trucks
The buttons on drivers door lock quit working. is there some kind of reset
Short answer is no.
If none of the locks work, could be a lack of voltage such as a blown fuse.
If all of the locks work but not from the driver's switch, its probably the switch.
Jul 05, 2012 | 2004 Ford Explorer Sport Trac
My Frigidaire model no LTF2940FSI will not fill with water...any suggestions?
The unit needs to sense the door lock before allowing to fill,start unit and listen for the door lock system, if the lack fail to either sense the door or the prongs on the door are broken, this will happen.
Part number for door lock 131763202 Part number for door striker 131763310
I hope this helps...
Jul 11, 2011 | Frigidaire GLTF2940ES Front Load Washer
I am getting error DE in my washing machine, need solution for this. Kindly give me the service error code for LG WF-T7516HN top loader
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Dec 03, 2010 | LG Washing Machines
Power door locks have gotten weak. do they need to be lubricated? Are the door locks electrical or are they run from the engine vacuum.
The door locks are electric. This could be from a lack of lube but more likely corosion of or dirt in the switches or ground path. Remember all the door lock switches rely on the main switch.
Feb 26, 2010 | 2000 Ford Windstar
Automatic door locks will not work
Probably the door actuator - a part inside the door that activates the lock, particularly if neither the interior lock switch or the remote do not lock the door.  Once the doors lock the horn will beep again - the lack of beep indicates the vehicle is not secure.
Nov 17, 2008 | 2004 Honda Pilot
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
