Paper not feeding on the left hand side of our lexmark 5100
Paper inserts in to printer ok but when paper starts its print cycle the paper is dragged quicker on the right hand side of the printer .Consequently the paper goes in crooked and jams.
    Scholar:
  • 174 Answers
Open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Posted on Nov 25, 2008
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
X5470 Paper Feeder
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......
Good Luck......
Jan 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper Feeder
Good Luck
Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
My paper goes to one side when printing starts and it does not print ny work
There may be a scrap of paper stuck in the machine, interfering with normal paper feed. Turn off the printer, and try to force a sheet of paper through the printer by hand. Feed the paper only in the normal direction that the paper goes. Forcing it by hand may push out the stuck scrap. Thin cardstock can be used instead of paper.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
Paper pulling
Be sure your paper guides are tight against the paper. If so, then clean the feed wheels with a damp cloth (just water). If this helps temporarily, you might need to replace the feed wheels.
Jul 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Easyshare 5100 not printing on correct side of paper
Load a single 8x10 page and press Copy + Cancel until the printer feeds the paper. It will spit it out blank. Try printing another photo. Make sure Kodak logo faces up when you load it
Jul 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Lexmark x3350
Feed the paper manually into the printer:
Place a sheet of plain A4 paper in the paper feed tray.
Move the paper support on the left-hand side to the left end of the paper.
Press the paper feed button.
If the paper does not feed, continue with step 2.
Check for any obstructions in the paper feed path:
Disconnect the cables from the back of the printer.
Open the front of the printer and check for anything that may be blocking the paper path.
Close the front lid and remove any paper from the paper feed tray.
Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
165 people viewed this question
jasbo
jasbo
