Question about Garden
I need to remove the flywheel on a 288 husqvarna chainsaw
I think i have an air leak from the seal behind the flywheel
  • 211 Answers
You need a rope with nods on it ,put it on the sparkplug gauge to block the piston in the cilinder,after that try to unlock the clutsch and the flyweel.Then disassembly the engine and change the seals.
best wishes Mihai71
Posted on Nov 28, 2008
New coil for chainsaw
the coil is on the flywheel side of unit. remove the recoil cover and you will see the flywheel and coil. your have to remove the ground wire from shut off switch and two bolts holding coil in place. when installing new coil you need to leave a 10 thousand air gap between the coil leg and the flywheel magnet for proper operation
Oct 10, 2014 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
My husqvarna 141 will not start??
Very unlikley to be an air lock, more likley to be a massive air leak, check the rubber induction tbe behind the carb mount it may have split, if not then a possible blown crank seal.
Feb 13, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
Wont start replced spark plug cleaned carb
If you have good fuel and a good spark it may be a mechanical issue, remove the muffler and check the condition of the piston face through the open exhaust port, any signs of damage or scuffing and it will need to come aprt to assess the damage, if all looks good it may be a crank seal leaking, the 36 was prone to blowing the seal behind the flywheel, also check the flywheel key in the flywheel has not sheared knocking the ignition timing out.
Dec 06, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My husqvarna 288 wont start, has extreme high compresion and cant pull cord with the spark plug in it. easy to pull with spark plug removed
http://www.ebay.com/itm/HUSQVARNA-288-CARB-REBUILD-KIT-COMPLETE-TILLOTSON-NEW-/140290773535 Your carb.may need rebuilt,remove and inspect,did you leave gas in it while it was stored,if so then carb is suspect.About 80.00 for a shop to repair,14.00 for you to do it.
Oct 10, 2012 | Husqvarna Garden
Husqvarna k750 wont idle down. I have replaced both rubber tubes and have even replaced the carb.
Replace the crankshaft on both sides. You will need a special puller to remove the seal on the flywheel side and the flywheel.
Sep 27, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a hsqv 346 which starts fine! trouble is as soon as I blip the throttle, it runs really really fast and wont return to idle. i have to switch it off. it was fin e a couple of days ago
This souds much like an air leak, if the engine is pulling air somewhere other than the carb it will lean the mixture and increase the idle speed, you are looking for a leaking gasget or crankshaft seal, this is no so easy without proper tools to do a pressure test, you will have to start changing parts in the hope you will find the cause, start with the impulse pipe on the carb mounting block, and the rubber induction hose, if not there remove the clutch and sprocket, behind the oil pump will be the crank seal, it may have come out of the bearing i have seen this happen, to get to the other crank seal you will need to remove the flywheel.
Sep 25, 2011 | Husqvarna Garden
Only will run when squirting gas in carburator.I have replaced carb plug air cleaner end fuel filter.Taken to repair shop,they say something internal.SO what?
Could be a massive air leak, possibly the crank seal has fallen out, or the cylinder base gasket has blown out, remove the flywheel and check the crank seal behind, remove the clutch, sprocket and oil pump and inspect the crank seal on this side,if they have fallen out, or are very wet, replace them, there are kits available to blank off the inlet and exhaust so as to put a pressure into the crankcase to quickly show where the leak is.
Jul 08, 2011 | Husqvarna Garden
I have a husqvarna chainsaw 41(1994-05) is what the model number is showing the carb has been rebiult new gasgets it has fire but will not run can u help
The 41 was quite prone to blowing the crank seal on the flywheel side, remove the flywheel and check, at the same time check the flywheel key has not sheared, behind the carb fixing plate is a rubber induction tube, make sure this has not split, als check the impulse seal underneath the induction tube.
May 19, 2011 | Husqvarna Garden
Trigger stuck on husqvarna 288 xp lite
The trigger and throttle lock are held with two roll pins, unfortunatly you need to remove the tank from the saw to take them out, i would guess the spring inside has broken.
Apr 28, 2011 | Husqvarna Models 181, 281, 288xp
Just rebuilt a husqvarna 372. New crank bearings, seals, all gaskets. Has good spark and gas. Why wont it fire?
If there is a good spark and there is good fuel at the plug the only reason it wont fire or do somthing is if the ignition timing is out, this can happen if the alloy flywheel key has sheard, remove the flywheel and check, unfortunatly if the key has gone it is a new flywheel.
Jan 25, 2011 | Husqvarna Garden
Garden Logo
304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
