Question about Sony KV-9PT50 Television
Fried something :)
KV-9PT50 was dropped a couple feet wouldnt come on. I removed the case and saw that the small circut board that plugs into the back of the picture tube had come loose. I reset the board holding the edges of the board and turned on the set and it worked fine.Then in a fit of stupidity as i was closing the case i decided to make sure the board was seated and placed my hand flat on the circut board,heard a little pop , and it of course wouldnt come on again .Im guessing i found a capacitor and fried something on the littte board . I dont know what the board is called or its part number or if it is available , set was built in 96 . Any help would be appreciated
    Sergeant:
    Champion:
  • 346 Answers
The part that was fried you need to give me the location number on the board.the location # is written on the green side of the board
Posted on Nov 27, 2008
My Sony KV-9PT50 has no sound.
is there a audio when you using the av input using a dvd player or a camera? if there no sound in any input you selected....check the speaker and if the speaker is ok...... check the audio amplifier...in you do not have any knowledge in electronic do not try this cause you might electric shock better go to the service center...
Aug 11, 2007 | Sony KV-9PT50 Television
Left earbud has no sound
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.
3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need:
- 1 small soldering iron
- one set of new wired earbuds (no volume control or mic... just plain earbuds)
- jewlers phillips head screwdriver
- one small flat screwdriver or thin flat edge to pry the cover off.
- one needle or thumbtack
Directions are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.
Directions:
- TURN OFF HBS 700
- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.
- remove the screw located under the plug
- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.
- remove the earbud cup and set aside. (if working on left side, also remove the charger door.)
- the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.
- once case is removed from circut board, you will see where the earbud soldered to the board.
NOW FOR THE FUN STUFF...
-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).
-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire.
BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.
-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.
-solder the new earbuds in place of the old ones. + to + and - to -.
-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.
-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.
NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.
-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.
-replace the earbud cup, battery door and power switch if it fell off.
-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.
-Re-insert the screw and plug.
DONE!
If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out the hard way)
I hope this solution was helpful
Oct 17, 2013 | LG HBS-700 Bluetooth Headset
Picture wont come on
hi. if any of the little copper bits are tutching the fat bit of copper in the middle of the arial that go into the back of the tv you wont get a picture and you might not have the right conecting bit from the arial to the tv as you get male and female ones. or you mite need to retune your t.v as evrything has gone digital and if something has interupted it. it will need retuneing and will need a satalite or a channel 5 arial. hope it helps thanks sean
Nov 30, 2011 | Sony KV-9PT50 Television
I Drop My Samsung J800 In the sea water and now it kinda
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Feb 22, 2010 | Samsung SGH-J600 Cellular Phone
I dropped my phone in water and now the phone work sometimes. Is it possible to fix.
Feb 15, 2010 | Motorola Mobility RAZR V3
It takes minutes, sometimes hours to for pic to come on. high voltage problem! No diagram. Sony kv9pt50
maybe you problem is in the circuit board of the tv.loose solder joints.you need a technician to fix the trouble.do not do it yourself,if you have no knowledge in electronics circuitry.lethal voltage is present inside the unit.
Nov 28, 2009 | Sony KV-9PT50 Television
Kv-9pt50 no picture hv and sound ok
its either you have a problem in the horizontal output,most probably flyback transformer or horizontal output transistor or ther is a defective component in hori. section.do not do it yourself.lehtal voltages present.contact qualified technician.
Nov 11, 2009 | Sony KV-9PT50 Television
I have a Sony Trinitron model kv-a2921b. The TV
HELLO MIKE
I don't think your TV is totalled! It's more than possible that a speaker connection on the main board has come adrift and just needs pushing back in. Check connections on the speakers themselves and when you trace back the cables there will one or two push in connectors.
It may be a good idea to get the speaker connection plugs checked and resoldered. It is also possible that the fall could have jolted the audio IC and this should be checked for dry joints or cracked print on the board too.
Hope this helps (:-)
Oct 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Drpped phone in water. How do I remove battery?
Jun 03, 2009 | AT&T Motorola RAZR V3 Cell Phone - Black
Sony KV-9PT50 Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
