Question about Amana ALE331RAW Gas Dryer
Thermal fuse keeps blowing
Can a defective timer cause the thermal fuse to keep blowing on an amana ale331raw electric dryer?
  • jab7575 Feb 24, 2009
    My thermal fuse keeps blowing but it is NOT because the vent hose is kinked or due to the vent being clogged. I know this because I had a repair man out to my house for the third time in about a week. After putting on the third new thermal fuse he suggested that I run the dryer without the hose being connected. This would eliminate the hose or vent as a problem. Sure enough, about 50 minutes into the drying cycle the thermal fuse blew and the dryer shut off. Any suggestions as to what else could be blowing my thermal fuses?
    Sergeant:
    Champion:
  • 291 Answers
They will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Posted on Nov 25, 2008
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
Hi candwloc..
If the thermal fuse /thermostat overheats the dryer will not operate.
It's located on the blower housing and it cannot be reset.
A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
Please take time to rate me
Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
The dryer will not start but the timer is working
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
May 21, 2010 | Whirlpool LER4634J Electric Dryer
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
My dryer stopped working, using a multimeter I determined that the thermal fuse was open. I unclogged all the ducts then ordered a high limit thermal kit. After changing the fuse, it blew-up on the first cycle. It turns out that even though the high limit checked ok, it was defective. After changing both the fuse and the thermostat(included in the kit $25), the dryer worked correctly.
Feb 05, 2009 | Amana ALE230RAW Electric Dryer
Good Afternoon,
Unless there is something restricting the ventilation I think you are having a problem with the heating coil staying on too long. If that is the case, one or more heating sensors are bad. Let me know if this helps and thank you for using FixYa!
Nov 25, 2008 | Amana NDE2335AY Electric Dryer
Amana ALE331RAW Gas Dryer Logo
887 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
