Question about Avanti (WDE79BSS)
Avanti water cooler WDE79BSS
Where can i download a manual for the advanti water cooler model #WDE79BSS
  • 1314 Answers
SOURCE: my cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
Posted on Jun 03, 2008
SOURCE: avanti water cooler
it freezes up
Posted on Aug 28, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
shastalaker7
  • 1515 Answers
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
I need a manual for a garrison water cooler with fridge. model # MYL1032S-B.
manualslib... did resonate with your model... (you will have to look here... https://www.manualslib.com/m/myl1032s-b.html Hope this does it for you...
Oct 21, 2016 | Water Filters & Coolers
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Need manual for model 30030
Try this web link for all appliances and parts. http://www.appliancefactoryparts.com/gasgrillparts/brands/fiesta/eza30030.html#Grates,-Heat-Plates,-and-Angles You may not get a manual but the replacement part will come with an install instruction detail. Good luck.
May 19, 2014 | Fiesta Advantis 3000 Grill
Advanti GFitT300 owners manual to down load
TRY TO DOWNLOAD FROM:
http:fitness.manualsonline.com
or go to web page from http://manualsfactory.com
sincerely.
Nov 10, 2011 | Exercise & Fitness
There is a full 5 gallon jug of water perched atop the cooler, yet it does not dispense any water. I was able to fill 4 cups consecutively an hour ago...now it only drips. This issue has occured once...
Something is obviously clogged.
Try opening the valves and blast some air through perhaps from a tire compressor.
Of course use common sense and don't apply pressure to jugs, etc.
Nov 19, 2017 | Avanti (WDE79BSS)
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Water Leaking from pump
How COOL is this. At first I thought this was some crazy graphics card cooler that I've never heard of!
Well here is the manual anyway.
http://www.air-n-water.com/manuals/MMB12-4Manual.pdf
And here is a Parts Catalog from a company in Arizona I found at random. This one takes a little longer to load just give it time.
http://www.dialmfg.com/Technical%20Assistance/TECHINICAL%20PDF%20DOCUMENTS/2008%20Cooler%20Parts%20Catalog-all.pdf
Jun 10, 2009 | Cooler Master Coolermaster CoolViva Video...
Sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Mar 26, 2009 | Avanti Hot and Cold Water Cooler
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
Avanti (WDE79BSS) Logo
53 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
