I have deleted my virtual device driver - Computers & Internet
    Scholar:
  • 162 Answers
Restore your computer to last state.
Posted on Nov 25, 2008
What setting do i put my webcam on for a virtual book?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 29, 2012 | Logitech C170 Webcam
Tip
How to remove a rogue Alcohol SCSCIVAX drive from your PC.
This SCSIVAX drive is a virtual CDROM device that is usually created by Alcohol. Normally, the uninstallation of Alcohol will remove this device but its not always guaranteed.
There are two possible solutions to this :
1. If you still your copy of Alcohol, then reinstall it. Once installed, you should then be able to find a setting in Alcohol (under Options->Virtual Drive menu I think) & set the number of virtual drives created on startup to zero. This will make the SCSIVAX drive disappear. Once gone, you can uninstall Alcohol again.
2. The other option, if you are comfortable with registry editing, is this :
Run regedit.exe, then in the left pane, navigate to :
Hkey_Local_MachineSystemCurrentControlSetServices
Right click on the Service branch & select 'Export'. This will create a backup of this particular part of the registry.
Next, inside this Services folder, you should find keys for the Alcohol driver. Depending on the version of alcohol you had installed, these will be named either a347scsi and a347bus OR vax347s.sys and vax347b.sys
Delete each of the relevant keys.
Close regedit, then open the windowssystem32drivers folder & delete the files of the same names. (Or move them to another folder if you prefer, just in case!).
And presto they will be gone !!!!
on Jan 07, 2010 | THQ Alcohol 120% (alcohol120)
Microsoft Virtual WiFi miniport adapter does not start
then delete the driver and go to the main web page drivers and downloads an re install the driver the PC rarely finds the driver for you.
Oct 02, 2012 | ASUS U50ARBBML05) PC Notebook
I need the drivers umax astra 5600 for windows 7
Hi, You could try and use it in an XP Virtual machine
Steps to take to check, if you can use Virtualization http://www.microsoft.com/windows/virtual-pc/support/configure-bios.aspx
Give info on all Cpus From Intel and AMD http://en.wikipedia.org/wiki/X86_virtualization
Virtual PC & Xpmode. http://www.microsoft.com/windows/virtual-pc/download.aspx
When you have XPmode and Virtual PC set up add the XP drivers for the scanner to the XP virtual Machine then connect the usb cable to W7
You should now be able to use the scanner in the XP machine.
Please contact the scanner manufacturer and see if they can provide the driver for Windows 7. Also, if the driver is for older operating systems, you can install the device driver in the Compatibility Mode.
thanks for rating Good luck
Jan 14, 2011 | Umax Office Equipment & Supplies
This is message error appear during I install canofile : RNBOVDD.DLL An installation virtual device drive failed initialization choose.'close' to terminate the application
The RNBOVDD.DLL is a Device Driver used for DOS and Windows 16-bit...so needs to be removed hence follow the steps listed below.
Run the Registry Editor by typing in regedit in the run search bar and Select the HKEY_LOCAL_MACHINE window.
Double click on SYSTEM. Double click on CURRENT CONTROL SET. Double click on
CONTROL. Select VIRTUAL DEVICE DRIVERS.
Double click on VDD:.......RNBOVDD.DLL line on the right side of the window.
Delete RNBOVDD.DLL. Confirm by pressing OK.
Shutdown and restart Windows.
ALL THE BEST...................
Feb 21, 2010 | Canon Canofile 2.01 Full Version for PC
Find free driver for umax astra 5600 scanner for OS windows7
I have Umax Astra 5600 scanner but it dose not work in Windows 7
Nov 16, 2009 | Office Equipment & Supplies
Microtek Scan Master 5900 hrdware error -3
Code 3 The driver for this device might be corrupted, or your system may be running low on memory or other resources. (Code 3)
Here are some things that you can try to resolve this problem.
Close some open applications
If the computer has insufficient memory to run the device, you can close some applications to make memory available. You can also check memory and system resources, and the virtual memory settings.
  • To check memory and system resources, open Task Manager. To open Task Manager, press CTRL+ALT+DELETE, and then click Task Manager.
  • To check virtual memory settings, right-click My Computer, click Properties, click the Advanced tab, and then click Settings in the Performance area.
Uninstall and reinstall the driver
The device driver may have become corrupted. If the driver is corrupted, uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Install additional RAM
You may have to install additional random access memory (RAM).
May 21, 2009 | Microtek SCANMAKER 5900 Flatbed Scanner
Touchpad not scrolling
  1. Unistall the touch pad driver from device manager.
  3. then Click Here to Download the Drivers
  4. Install the Drivers and Restart the computer.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 30, 2009 | Computers & Internet
Driver
Second the Vuescan reco. That's what I use. OTOH, a dual boot machine with an XP partition can also solve the problem. A real PITA but feasible (I have one).
Jul 29, 2008 | Konica Minolta Dimage Scan Elite 5400 II...
On vista i have vmware 6
Your Guest OS uses a Virtual VGA adaptor. As with a normal computer it needs drivers. This usually is installed through VMware Tools. (VMware tells your guest OS there are all kinds of virtual devices. They don't exist physically but need their drivers since VMware uses the virtual devices to handle the Host PCs physical devices.
In order to install VMware Tools, go to:
VM > Install VMWare Tools.
Remember that you need Administrator rights.
Need more help? See the link below:
[Installing VMware Tools]
This should do the trick, let me know if this solved your problem.
Greetings,
DarkNeogen
Jan 23, 2008 | Microsoft Windows Vista Ultimate Edition
Open Questions:
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
