Question about Acer AL1912B 19" LCD Monitor
17" Acer LCD does not display.
I have a 17" LCD and it does not have a display even when the light is green. When I shine a light directly onto the screen, I am able to view it very faintly. I read on the forums here that the possible problem may be the inverter board (sorry if misspelled). Could it be? And if so how easily are those changed? Does anyone know a monitor repair company in Chicago?
  • 624 Answers
Hi Needtofix, It?s not terribly difficult but you do need some experience handling and working on electronics, tools, a good mechanical aptitude, attention to detail and the willingness to risk doing more harm than good if you make a mistake. The other thing to realize is that you are going to have to invest a couple hours of your time researching, purchasing and installing the components. So if you are willing to spend a couple of hours to save about $100 then it?s worth it. As far as a contractor in Chicago you might try searching this site, but if that fails just look in the phone book for computer repair. I suspect the hard part will be figuring out which one to go to. Let us know how it turns out and if you find a good repair shop you might pass this site on to them so that they can register their services here.
Posted on Jan 06, 2007
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
We were watching tv, and the picture went out and all there is now is a light green screen, there is audio but no picture. Can this be fixed
it can be fixed...shine a flashlight onto the screen...if you can see a picture then it is the backlight that has gonethis site will show you how
have fun :)
Mar 07, 2010 | Dell E173FP 17" LCD Monitor
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Princeton VL1715-1 no display
From what you say there is probably not much you can do with it, the parts inside are SMD, to small
to work on. If you could still see txt on the screen when you shine your torch, it could be fixed by
replacing the back lighting PCB.
Hope this helps
Have a nice day.
Dec 22, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Green Light, no Display - Gateway FPD1730
I picked up a FPD1730 monitor for free which was just sitting out in my apartment hallway. I suspected something was wrong and sure e**ugh there was ** backlight, but I could see faint video when I shined a flashlight on it.
A quick Google search of the inverter model # led me to a German forum which suggested replacing the fuse labeled "F1" on the inverter board. I don't have a matching fuse on hand but I bridged the connection with a wire and sure e**ugh the backlight came back on. Short-circuiting like this is definitely **t 100% safe but if you can find a 4A fuse then it's a really cheap and quick fix.
Jul 29, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Oct 11, 2006 | BenQ FP767 17" LCD Monitor
Acer AL1912B 19" LCD Monitor Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
