Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Door open alarm going off with door closed
Alarm going off but temp still same. I don't have a owners manual
  • Tom Hurley May 11, 2010
    is the screen scrolling?
  • Michael Willsher May 11, 2010
    there are two kinds of door switches that Viking used, one is a proximity sensor that detects the door being closed, the other is a switch that works off of the upper hinge, it may be out of position, the proximity sensor is harder to repair and test. For that you may need a technician
  • 6,927 Answers
If the temp is to low,it could be the defrost timer sitting still on defrost mode.The timer should just allow the defrost to be in mode for a little while,instead it is on defrost all the time,and the compressor is working overtime trying to cool it.Have the defrost timer checked,or replace it,If I can help anymore,let me know.
Posted on Aug 20, 2009
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ... > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ... > Manage My Life > Questions
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
How do i get to the door ajar alarm in my 2002 kia sportage? Want to yank the alarm out.. Is it under the radio? Want to get an idea before i take the dash off again
there could be a bad or not totally depressed door switch/es when all doors are closed, assuming the alarm system module (not sure of the name, some manufacturers call it body control module-'BCM') is good. you may try the following:
1. if there is, tighten each lock nut (or mounting nut) of the door switches, to bring out each door switch so that they will be fully depressed when the doors are closed.
2. to find out which switch/es is not being fully depressed when door is closed: while (& all doors closed) door ajar alarm is on, open one door & manually depress the door switch (try to depress several times - might be sticking). if alarm turns off you found the switch, otherwise continue to the next door. but before proceeding to the next door, tape down that first door switch (you may have more than one?) once you found the switch that is not being fully depressed when door is closed, tape down that switch (to keep the alarm turned off). go back to each taped down switch. remove tape & close door, if the alarm turned off when the door was closed (switch is fully depressed=good), then go to next.
3. you can skip 2, just install spacer to doors. spacer can be a thin piece of plastic (or something weatherproof cardboard) to make the door switches to fully be depressed when doors are closed., not too thick that may prevent door from properly latching). tape them first, then use good adhesive if they work.
other possible causes are bad door switch, broken or detached wire, or bad BCM)
(note: the door switch is a push button which looks like a small protruding nail? & mounted at the door opening, which will be depressed by the door upon closing).
Oct 03, 2015 | Kia Cars & Trucks
Why does my 1999 Lincoln Continental alarm system go off by itself and then shut off after 5 or 10 minutes?
this could be the door striker plastic has broken off this is the post sticking out of the frame when you close the door the lock closes around the striker to keep the door closed this striker could also have moved slightly from opening/closing the door thousands of times try this open your windows get out close all doors set the alarm wait a minute then try to lightly move the door/s in and out by grabbing the door at the rear part where the door locks to the frame where the striker is if it has any play in it the connection will break and this will make the alarm think the door has opened and the alarm will sound getting the door to close tighter will stop it from happening this is also true for the trunk if you press down on the trunk or your able to pull up on it a little the same thing will happen its loose and will trigger the alarm if this is not the problem I would then go to the door pin switches that turn the lights on/off when the door is opened/closed especially if the alarm was aftermarket installed but you can be sure the alarm thinks that something is opened and the door/trunk/hood are the only places that they are
Aug 21, 2014 | 1999 Lincoln Continental
Refrigerator door alarm won't go off
Attached is link to users manual.
Manual says that Door Alarm will sound if any door is open for more that 2 seconds and will ssop when door is closed.
Can you locate the door switches?
Aug 20, 2014 | Star Manufacturing GE Profile PFSS5PJX...
The anti-theft alarm goes off everytime you open door regardless if it is locked or not
Interesting, seems alarm has been set-off before<now circuit is ON> and not been re-set back to neutral<re-set circuit to OFF> so when doors are closed, alarm memory retains previous set alarm memory <circuit set to ON>. It'ill go off again whenever door being opened, regardless it have been armed or left open as the memory circuit recognise it still as before alarm set-off<circuit is set ON>.
Solution, 1) Read your car owner's manual in the alarm section, read on how to re-set alarm to neutral if it has been set-off while armed [my experience is by turning the ignition key as if you are going to start the car engine but do not start engine then back to off position, do it 3 times as it will beep after 3rd run]. 2) On 4th run, start the engine, lock all doors then unlock it, 3) Turn off engine, get out from car, lock doors and arm alarm. 4) Dis-arm alarm, open doors and see if it still set-off alarm as before.
If all that doesnot work, go to your local dealer as alarm system has a system fault that can't be fixed without proper equipments.
Follow the instruction on how to accept and mark advise as giving you a core solution. Return a thumb up and praise response. Thank you.
Jan 05, 2011 | 2000 Honda Passport
How to disarm car alarm
May 09, 2010 | 2001 Nissan Pathfinder
Door alarm on and not cooling
If its the door alarm specifically, and not a temp alarm, assuming the door is closed of course check a couple of things. When you say its not cooling, is it not cooling in both sides, one side, part of either or both sides - i.e. top is warm and bottom is cold? My first door alarm thought was its possible door switch is bad, causing both light to stay on and alarm to think door is open. Is it especially warm or hot near a bulb in either side? If its warm at top, I would look into your evaporator fan motor operation, If its not cold on one side and cold on other, that could be several things, too many to list without specific temps.
Visit: for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
Mar 22, 2010 | General Electric GSHF5KGX Side by Side...
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
Nov 12, 2009 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Husbands 2003 dodge ram, it beeps when sets the alarm system, however, upon jumping on truck messing with door handles, alarm does not go off, why
there are all different type of alarm set ups ur truck possible set up for voltage drop (open door light goes on )sets off alarm-- if truck has aftermarket sensitivity alarm and not going off will have to adjust the unit to make more sensitive
Oct 26, 2009 | 2004 Dodge Ram 1500
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
379 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
